[Z06] Clutch Shimming Made EASY with NEW Tick Performance Slave Cylinder Shim Kit - 3 Pack!
Former Vendor
Any of you who have installed a clutch into a newer GM vehicle have likely heard of (and measured for) a shim that can go behind the slave cylinder to ensure proper bearing travel (and thus, clutch disengagement). You may have seen our popular thread: http://ls1tech.com/forums/manual-tra...need-shim.html
I'm proud to announce that Tick Performance is now making the use of shims even more precise by offering THREE difference thicknesses:
While you're at our site, take a look around! We offer thousands of products and FREE SHIPPING on any order over $100! We look forward to doing business with you.
- Tick Performance Slave Cylinder Shim (.055")
- Tick Performance Slave Cylinder Shim (.113")
- Tick Performance Slave Cylinder Shim (.180")
BFTD
what do i do if i have zero clearance i.e my slave in the fully seated position with no spring is still pushing on my clutch finders by .100
answer me that one hot shot
Yeah I guess it's not as common to have the opposite problem. Glad you figured something out. My car shifts so much smoother now. Unfortunately I had to rip it out again to remedy the problem.
