Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Z06 Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2011, 01:50 PM   #61
sabastian458
CF Senior Member
sabastian458's Avatar
Quote:
Originally Posted by Milan View Post
Vararam products are junk but they sure do produce results at the track.
I replaced my Vararam with a supercharger
Thats kind of a catch 22 statement. If they are junk, they wouldnt perform. Their fitment on some vehicles are junk, but the product is sound.
sabastian458 is offline   Reply With Quote
Old 01-13-2011, 03:28 PM   #62
kh400
CF Senior Member
Quote:
Originally Posted by sabastian458 View Post
I just finished installing my Vararam. I will say this, I am a fully capable mechanic. I can rebuild manual transmissions, engines, and most anything else. I have no fear in tackling any repairs. But this, this I will never do again. Took 5.5 hours. Seriously. I took out a T56 from a 68 Camaro today to reseal the trans and install a twin disk. That took 2 hours to drop, in my garage on jack stands by myself. And installing this intake took me 5.5, I will stay 30 mins of that was because I couldnt read the instructions about the Z06 screens.
The fitment of this intake on my car is HORRID. This may just be specific to my car, Im not sure.
The ram ducts fit good, but the center piece that connects the 2 ducts took a lil work to get the holes lines up, but nothing too drastic. But when trying to fit the radiator shroud back into place, that took 1.5 hours in of itself. The ram tubes keep the shroud from being able to move in the specific angle needed to fit back into its place. I had to bend, fight, twist, scream, and beat the thing into its place and it still doesnt quite fit perfect.
Once that was installed, I went to button up with the Power Duct. That is where the 2nd half of my time was spent. This does not fit the way the instructions say. Even after manipulating the pieces for hours, it still does not fit right, but I have it together and running. I can try to explain the misfitment, but pictures work better. So here are a few I snapped while between fits of anger.
What was on the car when I bought it.
Click the image to open in full size.
This is how it is suppose to install, with the MAF being at the very end of the Power Duct and right at the Throttle Body.
This is how the MAF is suppose to be according to instructions.
This is the reason for the trouble. The tubing, under no condition, fit the way the instructions say or show. Physically impossible. The bend in the Power Duct does not appear to be enough for my Z. The intake duct that came off had more of a turn back when coming from across the radiator.
So this is the result of 5.5 hours. Note that the setup still doesnt fit very well. You can see that the Throttle body to Power Duct connection is in a bind still. And I had to move the MAF to between the Vararam and the Power Duct. Even in this configuration, the Power Duct is still pushed against the bottom of the hood. But it is together.
I will NEVER buy an intake system like this. Of course this may just be with just my car. I have not read of others with this issue, just me. I typically change out my cars in the 1.5-2.5 year range, and I will say that after this install I will just skip the 30-40hp and stick a blower on the car. It would take less time.
NO, it's not just you or your car. I too am a life long auto tech [40 plus years] and I had the same problems. The power duct still interferes with the closing of the hood. Also, I had to install the MAF where you did. I did like the throttle response once I was finished though.
kh400 is offline   Reply With Quote
Old 01-13-2011, 04:49 PM   #63
sabastian458
CF Senior Member
Quote:
I love it too, just wish it would fit correctly. I can def tell that there has been a performance increase by the seat of my pants feel. Too bad I havent been able to drive the car more than 3 hours last week tho.
Old 01-13-2011, 06:31 PM   #64
bethunsl
CF Member
bethunsl's Avatar
I purchased my Z with the vararam already on it. It had lean codes until I installed the screen from Haltech. The fit of the factory duct was not that good so I replaced it with a powerduct from Zip. Everything looks and works much better than it did before and I'm now happy with the system. Hopefully later this spring I will get a tune done on the car.
bethunsl is offline   Reply With Quote
Old 10-05-2011, 12:53 PM   #65
v84life
CF Senior Member
v84life's Avatar
Jeremy Evans
Here is mine no fitment issues what so ever, the m.a.f sits directly in the plastic of the power duct on the inlet side maybe that is you're problem I do not have a red coupler on each side of the m.a.f that is only if you are using the stock air bridge.
v84life is offline   Reply With Quote
Old 10-05-2011, 01:04 PM   #66
sabastian458
CF Senior Member
Quote:
[/IMG]
My maf does not fit inside of the power duct. I have since moved my maf from infront of the throttle body to the section betweent the filter housing and the power duct. The Maf kept moving back slightly, causing contact with the 90mm DBW blade and throwing the car into limp mode.
It is still a pain to fit but it all fits now, just super tight. Also, getting the filter housing on is a PITA because the radiator shroud is bound up against it.
Performance is wonderful tho.
Old 10-05-2011, 06:22 PM   #67
v84life
CF Senior Member
v84life's Avatar
Jeremy Evans
Ok well maybe it depends on the year but on mine the m.a.f snapped right into end of the power duct I do have a 93mm Delphi M.a.f not sure if that makes a difference and that is how the instructions I had said to install it for my application.
Old 10-05-2011, 06:41 PM   #68
sabastian458
CF Senior Member
Yeah, fitment has been known now to be sketch on some cars, but not all. After I installed this, some time later, I had my car tuned at Hientz Racing and they were the ones to find out my maf and throttle blade were hitting.
I'm not too worried about it now as I have found a way to have it fit on my car somewhat ok. But like I said, I love the performance of this intake system.
Old 10-05-2011, 08:05 PM   #69
bobby777
CF Senior Member
Must have slowed down a tad-
bobby777 is offline   Reply With Quote
Old 10-05-2011, 09:10 PM   #70
momo20
CF Senior Member
momo20's Avatar
momo20
Send a message via MSN to momo20 Send a message via Yahoo to momo20
i feel your pain man...took me 6 hours...only longer cause i was cleaning everything while i was in there...but mine fit good..its just tight getting in there and doing the work...my neck was deft sore for a few days
momo20 is offline   Reply With Quote
Old 10-05-2011, 09:12 PM   #71
momo20
CF Senior Member
momo20's Avatar
momo20
i installed mine in the same location as the orginal thread starter..is there an advantage to running it closer to the TB like you did?
Old 03-05-2012, 12:09 PM   #72
skull
CF Senior Member
skull's Avatar
jdmotox333 howtobeataguy skull333
Send a message via AIM to skull
guess not lol. i plan to tackle mine in the next few days. gonna be 65 degrees in the middle of the week ill try to take pictures. im still not totally sure how the part of intake that reaches down to the mesh grill is suppose to attach or go. mine came with no directions.
skull is offline   Reply With Quote
Old 03-06-2012, 03:14 PM   #73
sabastian458
CF Senior Member
Quote:
http://www.vararam.com/VR-B2_instructions.pdf
OR
http://www.101corvetteprojects.com/2...-installation/
Internet is used for more than just Porn my friend
Old 03-06-2012, 05:24 PM   #74
skull
CF Senior Member
skull's Avatar
Thanks alot. What do you mean there are things other then **** to look for on the internet???
I thought internet was a cover name for ****
Old 03-06-2012, 09:18 PM   #75
SCM_Crash
UIX Engineer to the Max!
Support Corvetteforum!
SCM_Crash's Avatar
You have no idea how close to true that is.
*serious face*
SCM_Crash is offline   Reply With Quote
Old 03-07-2012, 08:40 AM   #76
sabastian458
CF Senior Member
Quote:
*serious face*
Internet
90% ****
8% stuff thats creepy and can be also considered **** but i dont know about that....
2% useful stuff
lol
Every try to watch Youtube videos and click the video's on the right of "similar" stuff. How many does it take until you are on the wrong side of youtube watching some odd/messed up/ WTF videos? lol
Old 03-07-2012, 10:48 AM   #77
skull
CF Senior Member
skull's Avatar
Lol the next video duh
Reload this Page Vararam Intake install
Tags
c5, c6, corvette, fitment, install, installation, intake, intakes, issue, maf, powerduct, problem, vararam, vr, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
