Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-17-2010, 11:56 AM   #1
Z06seal
CF Senior Member
Default mushy clutch pedal after hard driving
When I take my car out for a spirited drive, the pedal gets mushy, and at about 20% pushed in, it's very loose, almost like air is in the line. it sometimes won't even come back up once it gets to that 80% out point and I have to pull it with my foot.
This usually happens let's say I go 0-100ish or just do a lot of high rev shifting.
I believe this is a known problem, and the only related search I got was a thread from 2002 so I didn't wanna bump that up.... Some people have said it's the master cylinder/slave and I need to get one that's made by TIC or something?
Thanks!
Z06seal is offline   Reply With Quote
Old 12-17-2010, 12:08 PM   #2
ZZOOM06
CF Senior Member
ZZOOM06's Avatar
Send a message via AIM to ZZOOM06
Thanks!
This is very common with the stock hydraulics. It will only get worse with time, especially if you drag race the car. A Tick Master cylinder will cure the problem once and for all.
Jimbo
__________________
ZZOOM06
'03 EB/Mod/blue ZO6. mods: V-ram, MGW, 3" powerstick exhaust, ARH 1-7/8" race headers, LME/V-Max 416"LS3, Y-T Rollers, 42# SVO's, VMax ported AFR225's & Fast 90/90, 0Z700/Tick, Level 5 trans/diff, RPM brace, V-E Mod/Blue interior, SSR GTH Alloys, 543rwhp/493rwtq, all motor. 10.47@133, 11-15-13, @MIR
ZZOOM06 is offline   Reply With Quote
Old 12-17-2010, 12:42 PM   #3
Z06seal
CF Senior Member
so that guy was right...
and is it an easy install? I don't have access to a lift that easy, so most of my work that's done uptop, I can handle usually...
eta: apparently the front wheels need to come off and also the clutch pedal. sounds like some serious PITA to install. the DIYs are there, but all the picture/diagrams are missing in them... people need to learn to use imageshack. lol
Old 12-17-2010, 12:48 PM   #4
skyavonee
CF Senior Member
skyavonee's Avatar
michaelschiavoni
http://www.tick-performance.com/tick...dy/hydraulics/
Might as well add a remote bleeder while doing the master.
skyavonee is offline   Reply With Quote
Old 12-17-2010, 12:50 PM   #5
skyavonee
CF Senior Member
skyavonee's Avatar
michaelschiavoni
and here's a post on installation:
http://forums.corvetteforum.com/c5-t...r-install.html
Old 12-17-2010, 12:59 PM   #6
Z06seal
CF Senior Member
damn, that's the one with the missing pictures =/
pics would help alot
Old 12-17-2010, 01:25 PM   #7
ZZOOM06
CF Senior Member
ZZOOM06's Avatar
Go to Z06vette and do a search for "tick install". I'm sure Paul's pics are still there.
Jimbo
Old 12-17-2010, 07:08 PM   #8
zeevette
CF Senior Member
zeevette's Avatar
Quote:
Jimbo
I had a hell of a time getting the clutch pedal assembly back together. There's three nuts to reattach that're close to impossible to reach. I recommend removing the driver's seat for a little more room. There's other areas of the install that're difficult, and I had the drivetrain out! It helps to be very limber/young, or have help that is.
__________________
'02 black/black. LGM headers/cats/X. iForge "Aero" 18/19 combo. Koni FSDs. Trickflow/TEA heads,and HS rockers, MGW shifter.A&A Vortech V3si trim, and A&A COMP blower cam.RPS Twin Carbon Street. Tick master. Diff by RKT56. ECS brace. Pfadt diff brace. Somebody stop me...
I should be careful what I ask for....
zeevette is offline   Reply With Quote
Old 12-17-2010, 08:11 PM   #9
Ranger
CF Senior Member
Support Corvetteforum!
Ranger's Avatar
Thousands of Corvette owners have cured or avoided pedal issues entirely without installing an aftermarket part. Changing the master is certainly not the place to start.
First step is watching this video.
Now, inspect the clutch fluid and tell us what the reservoir looks like.
Next, tell us what are the mods on your car.
Ranger
__________________
'06 Z06 red 300 passes
Bone Stock Stock Tires……11.02 127.25 1.70 video
Bone Stock DRs......….…….10.71 130.32 1.60 video
'02 Z06 350 passes
Bone Stock Stock Tires……11.81 117.26 1.78
w/ CAI & DRs………...........11.52 120.21 1.64 video
My PRs Burnout Launch Shifting Clutch Care
Ranger is offline   Reply With Quote
Old 12-17-2010, 10:35 PM   #10
The Evil Genius
CF Senior Member
The Evil Genius's Avatar
Location: Huntsville, AL HAWG: "this is Off Topic...it can get a bit north of care bears and strawberry shortcake in here"
I have no problems at all with the stock hydraulics, and I'm not easy on the car. I do, however, regularly change out the fluid with ATE super blue. Works like a charm. My guess is you have old/bad fluid, like Ranger suggests, and you don't need to replace the stock bits.
The Evil Genius is offline   Reply With Quote
Old 12-17-2010, 10:45 PM   #11
Ranger
CF Senior Member
Ranger's Avatar
If pristine clutch fluid (by swaps of the reservoir at a cost of about $10 and an hour's time) doesn't give you a normal pedal, then the next step is to change out just the master cylinder to the latest part number for your VIN. The cost of that part is around $100 and two hours or less self-help labor. You just need the part and the pages from the shop manual.
Ranger
Old 12-17-2010, 11:17 PM   #12
thumperZ06
Great State of Utah
St. Jude Donor '12, '14
thumperZ06's Avatar
Default fixes
thumperZ06 is offline   Reply With Quote
Old 12-18-2010, 01:36 PM   #13
Its Bruce
CF Senior Member
Its Bruce's Avatar
FYI, a new M/C and slave, to the latest PN, didn't work on my setup even after hours of bleeding via a remote bleeder.
Its Bruce is offline   Reply With Quote
Old 12-18-2010, 07:24 PM   #14
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Assuming you have a stock LS6 clutch, it's rated for about 350 rwhp/rwtq, plus 8-10%.
From you profile, we see that you car has the following mods:
B&B Bullets
BPP shifter
ARH 1-7/8" LTS
ARH X pipe w/ cats
P1SC Procharger w/ ECS mount
Alky Control
That's easily 30-40% above the capacity of a stock clutch.
You need to be looking for a clutch properly sized to your mods and aspirations.
Ranger
Old 12-18-2010, 07:32 PM   #15
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
I had the same problem after spirited driving. My fluid was very dark in color. I started doing the Ranger method each time I drove my car. Within a month the fluid was clear. It stayed like that for 2 years. I often check it. .
Strangely enough the spongy feeling came back a few months ago. My fluid is still clean as a whistle though. I started to do the Ranger method again and after 3 weeks its noticeably less spongy after hard driving. I will continue to do the ranger method until it feels normal again.
Toque
Toque is offline   Reply With Quote
Old 12-18-2010, 07:42 PM   #16
Z06seal
CF Senior Member
My car in 2006 made 382/361
Last week it made only 345/340
I'm blaming it on the previous owner not taking care of it, but with some work, It'll be back to around 380
so the car makes about 380 at the wheels, afaik it still has the stock clutch
now about the fluid
I did the fluid swap about a week ago with the medium size brake fluid. I used Prestone synth DOT 3 brake fluid I kept doing it until I had clear fluid after 30 pumps.
honestly since I did that, it kinda got worse, I'm worried I got air in the line while I was doing that, but I HIGHLY doubt it...
I'l check the video and do it again.
in your video I see you use Prestone DOT 4 and the GM DOT 4 fluids... why 2 diff brands? do you mix them up? which should I use?
and if I remember right, I used DOT3 in there, but I'm not positive.
I'll do it again and see if it's murky (I did it about 2 weeks ago) if not, I'll let you know.
so should I just get another GM master cylinder, or the tick one that's almost 3 times the cost?
Old 12-18-2010, 07:55 PM   #17
Ranger
CF Senior Member
Ranger's Avatar
Ranger, do you reccomend a specific fluid?
I use Prestone DOT4, widely available including Walmart, for about $2.60 for 12 oz.
Keep changing the fluid after each drive until the fluid stays clear.
If the fluid has never been maintained through its long life to now, the master cylinder seals may be abraded by accumulated clutch dust. I wouldn't conclude that is the case until the fluid is rendered to pristine condition.
Ranger
Old 12-18-2010, 07:57 PM   #18
Its Bruce
CF Senior Member
Its Bruce's Avatar
B&B Bullets
BPP shifter
ARH 1-7/8" LTS
ARH X pipe w/ cats
Alky Control
Ranger
I now have an ACT twin disk. My issues were not enough disengagement for both this clutch at current power levels and the LS6 clutch when the car was near stock (370rwtq). I don't believe power would have anything to do with the M/C's ability to push fluid from chamber A to chamber B. If you disagree, I'm all ears.
Old 12-18-2010, 08:28 PM   #19
Ranger
CF Senior Member
Ranger's Avatar
I now have an ACT twin disk. My issues were not enough engagement for both this clutch at current power levels and the LS6 clutch when the car was near stock (370rwtq). I don't believe power would have anything to do with the M/C's ability to push fluid from chamber A to chamber B. If you disagree, I'm all ears.
Proper functioning of the clutch hydraulics always relies on a correct installation of the clutch components.
An undersized clutch with inadequate clamping power for fwtq of the motor will slip, producing heat that causes vapor lock in the actuator.
Also clutch dust infused clutch fluid will abrade the seals in the master cylinder and cause pedal issues.
Ranger
Old 12-18-2010, 09:25 PM   #20
Its Bruce
CF Senior Member
Its Bruce's Avatar
Apologies, my post required an edit. The issue was lack of disengagement, especially into 5th gear.
Reload this Page mushy clutch pedal after hard driving
Tags
aggresive, air, c5, clutch, corvette, fluid, hard, lowers, mushy, pedal, racing, shifting, spongy, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
