[Z06] C5 Z06 Fast List Only
#161
Year of the Z06: 2001
Tires used on the pass: Nitto NT555R
Performance Mods (if any). Ported LS6 heads, 219/230 cam, fast 92
Which catagory:
C5 Z06 External/Internal Bolt On times (stock cubes, n/a, cams, h/c, all bolt ons)
60'.............2.0497
330'...........5.1939
660'...........7.7720
660’ mph...95.90
1000'..........9.9658
1320'..........11.8260
1320’ mph…121.33
Comments: name of the track: U.S 41 Dragway 3/30/14, weather conditions: Mid 50s, Density Altitude: 300
http://i417.photobucket.com/albums/p...ps8bbdaf4b.jpg
Which catagory:
660’ mph...95.90
1320’ mph…121.33
Updated.
#162
2002 Z06
Tires: 295/35/18 BFGoodrich Rival
Mods: none
Category: C5 Z06 Bone stock
60'.............1.898
330'...........5.322
660'...........8.088
660'mph....90.10
1000'........n/a
1320'.........12.417
1320'mph...113.96
Carolina Dragway. Jackson, SC. 10April2014 7:30pm
DA-586ft
Timeslip embedded in Video
Video:
thanks
Mods: none
660'mph....90.10
1000'........n/a
1320'mph...113.96
DA-586ft
Video:
thanks
#163
2002 Z06
Mods: none
660'mph....90.10
1000'........n/a
1320'mph...113.96
DA-586ft
thanks
Mods: none
660'mph....90.10
1000'........n/a
1320'mph...113.96
DA-586ft
thanks
Since non-OEM tires were used, this was posted in the second category. (Bone-stock, except just an air intake or modified air-path and drag radial tires or non-stock tires.)
This happened to me about 7 1/2 years ago when I replaced my paper OEM air filter with a drop in K&N. I immediately went out and purchased another OEM filter and ended up running better. I even kept it on the list that way all of these years since taking it over.
#167
First time out w Z06 and havent been to drags in long long time...My first time in RWD car, Im no drag racer either but this car is fast! I think i can get into 11's as-is because my 1-2 shift is laying serious rubber. There is time to be made there, Ill work on it next time
2003 Z06, M6
91 octane, 3/4 tank
All stock except:
B&M short shift
295/35-18 BFG Rivals, 24psi hot
New era ported TB
Vararam intake & bridge
ARH 1-7/8" headers swaintech coated w/ ARH cats & x-pipe
PAC1218 valve springs
Dyno tuned by Mike at New Era
Bilstein sport shocks
Empire dragway 6/20/14, 70F-75F
60' 1.879
330' 5.210
1/8 7.917
Mph 92.17
1000' 10.202
E/t 12.126
Mph 116.94
2003 Z06, M6
91 octane, 3/4 tank
All stock except:
B&M short shift
New era ported TB
60' 1.879
330' 5.210
1/8 7.917
Mph 92.17
1000' 10.202
E/t 12.126
Mph 116.94
#168
2003 Z06, M6
91 octane, 3/4 tank
All stock except:
B&M short shift
New era ported TB
60' 1.879
330' 5.210
1/8 7.917
Mph 92.17
1000' 10.202
E/t 12.126
Mph 116.94
2003 Z06, M6
91 octane, 3/4 tank
All stock except:
B&M short shift
New era ported TB
60' 1.879
330' 5.210
1/8 7.917
Mph 92.17
1000' 10.202
E/t 12.126
Mph 116.94
Fast List Updated
#169
Procharged F1X 7.18 @ 197
St. Jude Donor '09-'10-'11
1/8 mile data.
Year of the Z06: 2002
Tires used on the pass: M/T 275/60-15 3754X
Performance Mods (if any). F3R Procharger, Forged RHS LS 427, IRS, TH400, 25.3 NHRA Cage.
Which category: Power adder, any cubic inch.
60'............. 1.203
330'........... 3.234
660'........... 4.862
660’ mph... 151.54
1000'..........
1320'..........
1320’ mph…
Comments: Summit Motorsports Park 8/23/2014, Weather Clear 80 degrees, Sunny, DA unkown. RPM/DSS IRS 9" suspension.
NMCA JE PIstons LSX Drag Radial Class
My class was changed to 1/8 from 1/4 due to safety concerns with 200+ MPH 1/4 mile trap speeds.
Gary, although there is no official category I would like to post this information to show what the C5/C6 IRS combos are capable of.
On that pass I lifted the wheels a few inches and the car tracked straight down without peddling or excessive steering correction.
I would have run it out the back half as I am sure that would have been a low 7 second pass but the slip or timing tower was not setup for it.
660’ mph... 151.54
1000'..........
1320'..........
1320’ mph…
#170
2001zo6 fast list
2001 zo6
Tires used on the pass, size / brand/ etc. Hoosiers 275/40/17
Performance Mods (if any). 346cu ported 243s fast 102 btr cam
M12 trans stock gearing.
Which catagory?
Internal Engine Modifications - Head/cam
-> 346
60'.............1.519
330'...........4.414
660'...........6.831
660’ mph...104.77
1000'..........8.944
1320'..........10.723
1320’ mph…125.72
Beech bend raceway
bowling green ky
DA around 0 air temp was 50*
http://i60.tinypic.com/5owjli.jpg
2001 zo6
346cu
heads 243s by BTR
Cam 235/247 by BTR
fast102 ported and matched by BTR
M12 trans
342 rear
Rxt clutch
1-3/4 xs power headers
http://i58.tinypic.com/2v2tie1.jpg
Which catagory?
-> 346
660’ mph...104.77
1320’ mph…125.72
Beech bend raceway
bowling green ky
2001 zo6
346cu
heads 243s by BTR
Cam 235/247 by BTR
M12 trans
342 rear
Rxt clutch
#171
2001 zo6
Which catagory?
-> 346
660’ mph...104.77
1320’ mph…125.72
Beech bend raceway
bowling green ky
2001 zo6
346cu
heads 243s by BTR
Cam 235/247 by BTR
M12 trans
342 rear
Rxt clutch
Which catagory?
-> 346
660’ mph...104.77
1320’ mph…125.72
Beech bend raceway
bowling green ky
2001 zo6
346cu
heads 243s by BTR
Cam 235/247 by BTR
M12 trans
342 rear
Rxt clutch
Updated.
#172
03 50th anni
275-40-17 hoosiers
fidanza fly and clutch, kooks and vararam, wildwood master
bolt on
60' 1.587
330' 4.635
660' 7.179
660’ mph 97.29.
1000' 9.363
1320' 11.196
1320’ mph 123.44
cecil county 11/29 40s and partly sunny...
YES im resetting my own 3rd place by hundredth
trying out Hp tuners and HAve NO clue what Im doing... so Getting back to low 11s bolt on was great
I think this may be close to 300th pass and NO breakDOWNS so an accomplitshment in itsself.... not FAst BUT very reliable and consistent
275-40-17 hoosiers
bolt on
60' 1.587
330' 4.635
660' 7.179
660’ mph 97.29.
1000' 9.363
1320' 11.196
1320’ mph 123.44
#173
03 50th anni
275-40-17 hoosiers
bolt on
60' 1.587
330' 4.635
660' 7.179
660’ mph 97.29.
1000' 9.363
1320' 11.196
1320’ mph 123.44
275-40-17 hoosiers
bolt on
60' 1.587
330' 4.635
660' 7.179
660’ mph 97.29.
1000' 9.363
1320' 11.196
1320’ mph 123.44
Faster is better!
Updated.
#174
Cai and drag radial list update
2002 CORVETTE Z06
275/40/17 ET STREET RADIALS
ZIP TIE MOD ONLY WITH K&N DROP IN
CAI AND DRAG RADIAL ONLY FAST LIST
60'.............1.771
330'...........4.947
660'...........7.576
660’ mph...93.80
1000'..........N/A
1320'..........11.760
1320’ mph…117.49
DARLINGTON RACEWAY SC; FEB 7 2015.
https://www.youtube.com/watch?v=Sln6...ature=youtu.be
660’ mph...93.80
1000'..........N/A
1320’ mph…117.49
#175
2002 CORVETTE Z06
660’ mph...93.80
1000'..........N/A
1320’ mph…117.49
660’ mph...93.80
1000'..........N/A
1320’ mph…117.49
Updated.
#176
Old times but I just saw the list can I play?
05/01/2005
2002 Z06
ET Streets & Skinnes
H/C
3.73's
Cluctch
60'.............1.567
330'...........4.647
660'..........0. 7.271
660’ mph...95.35
1000'..........9.491
1320'..........11.364
1320’ mph…120.67
07/03/04
2002 Z06
Ziptie Mod
C5 Z06 CAI and DOT Tire Times (drag radial and bias ply)
60'.............1.648
330'...........4.935
660'..........7.623
660’ mph...92.75
1000'..........n/a
1320'..........11.85
1320’ mph…117.42
05/01/2005
2002 Z06
H/C
3.73's
Cluctch
660’ mph...95.35
1320’ mph…120.67
07/03/04
2002 Z06
Ziptie Mod
660'..........7.623
660’ mph...92.75
1000'..........n/a
1320’ mph…117.42
#177
05/01/2005
2002 Z06
H/C
3.73's
Cluctch
660’ mph...95.35
1320’ mph…120.67
07/03/04
2002 Z06
Ziptie Mod
660'..........7.623
660’ mph...92.75
1000'..........n/a
1320’ mph…117.42
05/01/2005
2002 Z06
H/C
3.73's
Cluctch
660’ mph...95.35
1320’ mph…120.67
07/03/04
2002 Z06
Ziptie Mod
660'..........7.623
660’ mph...92.75
1000'..........n/a
1320’ mph…117.42
BTW- you posted 11.85. Was that with a "0"?
Two very nice consistent H/C passes on different days with excellent 60's. Congrats.
Updated.
#178
Thank You. In reviewing the slip it is a 11.860. Bad copy
#179
Gary, could you be so kind as to add an 1/8 mile category. The popularity of 1/8 mile is growing big time with all racing organizations.
It can be an all-in-one 1/8 mile category for simplicity. However, I'll leave that to your discretion:
Performance Mods (if any). F1X-12R Procharger, Forged RHS LS 427, IRS, TH400, 25.3 NHRA Cage.
60'............. 1.153
330'........... 3.052
660'........... 4.611
660’ mph... 157.72
660’ mph... 157.72
#180
Received 2,054 Likes
2001 zo6
Which catagory?
-> 346
660’ mph...104.77
1320’ mph…125.72
Beech bend raceway
bowling green ky
2001 zo6
346cu
heads 243s by BTR
Cam 235/247 by BTR
M12 trans
342 rear
Rxt clutch
Which catagory?
-> 346
660’ mph...104.77
1320’ mph…125.72
Beech bend raceway
bowling green ky
2001 zo6
346cu
heads 243s by BTR
Cam 235/247 by BTR
M12 trans
342 rear
Rxt clutch
