[Z06] Tips for lowering 02 Z06
Hi...I want to lower my 02 Z06. I dont want it slammed low, just lowered enough to gain a handling edge over stock height. Any tips on the lowering process would be greatly appreciated.
Flash :seeya
Flash :seeya
Re: Tips for lowering 02 Z06 (flash1034)
Just got mine done today. Took it to Corvette Mikes, rather than doing it myself. Dropped it on the stock adjusters, about 3/4 all around. You should consider having a shop do the job, as an alignment job is in order as well, as part of the improvement program. I went to -1 deg front, -.8 deg rear camber, 6.7deg caster, 1/32 toe front and 0 rear. Added Eradispeeds all around while I was at it. Car looks and feels great, and will give me more grip at the track, as well as the local mountain roads.
Otherwise, there is a good article on lowering the ZO6 in the Tech Tips section of this forum, ander the C5 related articles.
