Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-06-2009, 02:36 PM   #1
skywalker
CF Senior Member
Default Differential output shafts
I am thinking of going to the hardened output shafts for my 04. Is this mod a do it yourself installation or are special tool required.
skywalker is offline   Reply With Quote
Old 03-06-2009, 04:38 PM   #2
vrybad
CF Senior Member
vrybad's Avatar
If you are handy, and preferably have a lift to make it easier, you should be fine.
I did mine in about 4-5hrs, being the first time I ever had the diff apart, and I wanted to take my time.
I had a lift, too.
It really helped.
You will need a press to remove the right side shaft, but that is pretty much the only real specialty tool you need, from recollection.
If you do the shafts, do the preload spring washers that place pressure on the diff clutch pack.
I had only about 15k miles on my car, and both OE washers had cracks in them, effectively weakening the preload on the diff clutch pack.
vrybad is offline   Reply With Quote
Old 03-06-2009, 04:53 PM   #3
skywalker
CF Senior Member
Thanks for the info. I assume the diff does not have to be seperated from the trans? Asfor the clutch pack spring washers, just use OEM replacements?
Old 03-06-2009, 05:12 PM   #4
vrybad
CF Senior Member
vrybad's Avatar
It has to be pulled back.
Unbolt the upper a-arms and lower shock bolts, pop the axles out, remove(or lower) the k-member, take the right side cover off, and unbolt and pull back the diff.
I did not take mine off all the way.
As you pull it back, the trans output shaft is removed far enough to pull the ring gear/posi unit out.
Just be careful.
Might need another pair of hands to help.
edit-I used the upgraded washers from DTE, they are quite a bit heavier than OE
Old 03-06-2009, 09:51 PM   #5
skywalker
CF Senior Member
Thanks again for the reply. Very helpful info. I don't have a lift but will be installing the shafts at the same time as the new clutch.
Old 03-06-2009, 09:58 PM   #6
vrybad
CF Senior Member
vrybad's Avatar
If you are doing the clutch, you'll have the whole drivetrain down anyway, so you'll be fine.
Good luck.
Reload this Page Differential output shafts
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
