Rear Fascia painted..when can I pull it off?
Just finished painting the rear lower fascia..I know the label says it dries in 10 minutes..I put about 5 coats on...but how soon can I pull off the tape/plastic..Im worried the paint on the tape will be gooey if its not completely dry...Thanks..Paully.
Corvette C5 Enthusiast
St. Jude Donor '08-'10
i was always told pull it off when the paint is still we so you get a crisp edge as opposed to letting the paint dry it can be a "cracked" edge. But i dont know if that applys with spray paint.
In the past I have started removing tape as soon as the last coat is applied.
