[Z06] Im sick of spinning!
okay last night at the track was the last straw, i need traction.
my 02Z with bolt-ons...
first run 13.5
second run 13.45
last run 13.02
Spinning through first and second...
im tired of these crappy times, guys what is the best set of Drag Radials i can use for my car to hook better? i want a set for street/drag use.
i heard mickey thompson et streets are awesome as well as nitto 555R
advice is more than welcome
first run 13.5
second run 13.45
last run 13.02
the nittos seem to be popular for both street and strip. problem with a dual purpose tire is that you'll give up something for something else.
if you have the cash the best bet would be to get a second set of rear tires and run a 17" drag radial at the track.
first run 13.5
second run 13.45
last run 13.02
first run 13.5
second run 13.45
last run 13.02
Launch technique is everything - I run 12.5 to 12.6 on Firestone Firehawks with stock drivetrain. Do a short burn out in staging to clean the tires - Try moderating your launch - 3000 RPM and side step the clutch, spin for 10-20 feet and hook up then bury the throttle. If you are spinning through second you are way overdriving the car. Check out the drag racing forum and search launch techniques. Many good threads there - the start means more than HP or tire types. Once you get that correct and consistent - then it is time to go with major sticky tires.
You have to learn to launch. I pull high 1.8s to low 1.9s with a stock car on my OEM tires. Here is a video -> Video
Dont just stomp on the throttle when the light turns green. Learning how launch and roll the throttle to floor
PLUS NEW TIRES. Tires that are over a year old or have too many launches on them just wont stick no matter what you do.
Launch technique is everything - ... If you are spinning through second you are way overdriving the car. .... search launch techniques. Many good threads there - the start means more than HP or tire types. Once you get that correct and consistent - then it is time to go with major sticky tires.
Be careful if you get DRs as your launch will need to change. Damage can occur if you dead hook. A good street/stip DR would be the MTs.
I recommend going to the FAST LIST and click on ranger. He has a great tutorial. This will be a good start. My launch technique is similar when I was bonestock except my launch RPM was slightly higher (3200-3700) depending on track prep and I would start to apply the throttle just prior to the top of the clutch release. I also did very large burnouts with my F1 SC tires. I have cut as low as a 1.75x 60' with this technique.
this is going to sound pathetic and pardon the noob question....but how do you do a burnout on a manual? i read rangers post but was still lost. i had an auto truck that made 400/454 and all i had to do was stomp on the brakes and gas at the same time to do a nice burnout. thanks
1) Car in Competetion Mode
2) Roll carefully through the water.
3) Stop out of the water where the surface is just moist.
4) Place car in 2nd gear.
5) Rev to 4200 rpm and dump the clutch.
Here is where is gets somewhat tricky.
6) Quickly bring revs to 6000 rpm and move left foot to the brake and add only enough pressure to stop forward progress. You may also need to feather in more throttle.
7) After I see smoke billowing from both sides of the car, I release the brake, roar forward, get back into the clutch and bring it to the line.
If the car stalls, backup into th water and pull forward again. Remember to place it in the Comp Mode since it has disengaged. Do not worry if you muff it up. We have all been there, done that. It is more important the that you do not break parts and have fun.
Currently, I use a line lock since using the above technique does put additional stress on the rear. (I had no problems in 181 passes prior to the line lock.)
Good Luck
Good question. It took me a little while to get use to.
Good Luck
Good Luck
You need to be in the moist area at a minimum for street tires. I prefer to slowly roll through. When using DRs, you need to have them wet. BTW- I'm using robz's computer to respond.
