Need input on drivetrain noise
Have a 2000 C5 @ 28,000 miles, no abuse
The noise sounds like the kind you would get with an older car when you have a worn U joint.
Just when starting out - there is a slight clunk before the drivetrain fully engages.
Chevy dealer changes the rear fluid (plus additive) which took it away for a while, but now it's back.
He also talked about replacing the rear half shafts at $600/side, but no gaurentee that that would solve the problem.
Any ideas?
Any ideas?
Wounded Warrior Escort '11
28K on the clock is nothing. The CV type boots aren't torn? Are you getting a loss of rear end gear oil from one of the seals? You stated a "clunk" type sound which does sound like the half-shafts, which by the way are a lot cheaper that $600 per side, although I'm not talking about labor, rather parts only. If you were hearing a click type sound then there is an easy fix for that. Have you checked the torque on the axle shaft nuts (33mm)?
