C5 stock wheels to c6 upgrade
Old 03-06-2020, 04:03 PM
ChuckBus
3rd Gear
ChuckBus's Avatar
Default C5 stock wheels to c6 upgrade
Looking to upgrade front and rear rims and tires to c6 OEM.
for the rear I heard everything to no shims needed to half inch.
what should I do?
if shims are needed can someone recommend a part number or product name.
thanks
Old 03-06-2020, 04:34 PM
MadMax96
MadMax96's Avatar
Probably didn't need to start another thread....... just sayin... https://www.corvetteforum.com/forums...ded-on-c5.html
I went with these adapters from Amazon:
https://www.amazon.com/gp/product/B01BFVGF8S/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01BFVGF8S/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
If I planned on doing anything extreme like drag racing I might have spent more - but these seem fine and got decent reviews. You will need to cut down your wheel studs for the wheel to sit flush against the adapters.
Old 03-07-2020, 07:55 AM
scorpiofox69
scorpiofox69's Avatar
I did base wheels from a 2012. To get aligned to the top of the fender (running Firehawks for shoes):
Rear: 20mm Hubcentric spacers
Front: 6mm spacers
Old 03-07-2020, 10:22 AM
ls1wolf
ls1wolf's Avatar
This is with a 1” hub centric spacer running a 305 tire
Old 03-07-2020, 02:04 PM
USAZR1
USAZR1's Avatar
Received 1,870 Likes on 1,085 Posts
That's interesting that some of you are also running a spacer in front, as all the 8.5" width front wheels for C5's, base C6's, and base C7's have the same +56 offset.
To C5 stock wheels to c6 upgrade
Quick Reply: C5 stock wheels to c6 upgrade
