GP: Sharp Light Innovations Dual Projector Low-Rise Headlight system.
Old 03-02-2020, 12:20 PM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default GP: Sharp Light Innovations Dual Projector Low-Rise Headlight system.
Tired of the flip up look, but still like the look of the headlights closed? We have you covered with our "Luminator" low-rise Dual projector headlight system. Replacing the aged and horrible factory housing with Hella sealed projectors, your cars headlights can join the 21st century.
The kit includes a reinforced Aluminum mounting frame, modified steel lifting arm, and stainless steel hardware and cast urethane shrouds (optional). Want to upgrade the output? Upgrade the low beams to HID and the high beams to our High Output LED.
If you really want to show off, you can add our switchback Angel eyes that interface with your turn signals.
If you're on a tight budget, you can purchase this kit without the shrouds too. and if you're still on a budget, keep the halogens and upgrade the bulbs later.
Installation is designed to be DIY with no permanent modification of your car's factory parts. (You can go back to stock any time)
Group Purchase Details:
This Group Purchase will run from Monday March 2 through Sunday March 8. On Monday March 9, we will order all the required parts to build kits that have been ordered. The discounted GP price comes from being able to order these parts in bulk.
Use the coupon code "luminator10" (no quotes) to get 10% off your Luminator order regardless of the options you choose.
Order your set today >>>>HERE<<<<
HID low beams
HID Low + LED high beams
With Angel eye option
Without Shrouds
Old 03-05-2020, 10:36 AM
TheRadioFlyer
Supporting Vendor
bump
Old 03-05-2020, 05:50 PM
bonesbrakr
bonesbrakr's Avatar
This still is a flip up look. Just not as much flip.
Its pretty much the same "style" housing just with smaller "bulbs".
Old 03-07-2020, 08:37 AM
TheRadioFlyer
Supporting Vendor
bump
Old 03-08-2020, 10:00 AM
TheRadioFlyer
Supporting Vendor
Sunday Bump
To GP: Sharp Light Innovations Dual Projector Low-Rise Headlight system.
Quick Reply: GP: Sharp Light Innovations Dual Projector Low-Rise Headlight system.
