[Z06] Service ABS System, Service Traction Control System
Well this morning the DIC showed no indication of the problem existing/persisting. This presents two schools of thought. There is a loose electrical connection and the problem will reoccur. Or...The problem was directly related to the conditions and the wheel hop that occurred simultaneously with the code appearing on the DIC. Time will tell... Nevertheless, I will still be checking the related electrical connections.
Thanks for the responses guys
I suspect you either didn't pull codes correctly, as every Corvette has at least a few Uxxxx codes, and you definately have one or more CxxxxH codes if you got the SERVICE messages, or you didn't realize that H codes are left in the computer as a diagnostic aid for intermittent problems.
I haven't pulled the codes at all. I didn't realize they would remain in the EBCM. That's an interesting and quite useful bit of engineering there. I will pull them and post them.
The fact is the C5 Corvette is a VERY sophisticated collection of computer hardware/software .... GM has done a HORRIBLE job of marketing how sophisticated the systems are in their cars. Look at the RPO F55 suspension option ... so good that Ferrari has licensed it and uses it in the 599 GTB Fiorano, and Audi has licensed it and uses it for the new R8.
The computers in a C5 manage almost every function in the car ... and if they don't manage it, they monitor it ... and post a Diagnostic Trouble Code (DTC) when they see a problem.
The format of the codes is AxxxxZ where A=the type of code (Powertrain = P, Chassis = C, etc.) followed by 4 digits, and at the end is either a C or H (sometimes both for certain codes) indicating if the problem is Current or History.
These cars are VERY complex .... there are many computers in them, and almost everything that occurs requires interactions between at least two computers .... turn on your A/C and you are "requesting" A/C ... it is ultimately the PCM that decides whether or not it is willing to turn on the A/C compressor, and it is programmed to "throttle up" the engine as the A/C compressor comes on-line so that you don't feel that "hesitation" as the compressor clutch engages.
If you have a "problem" with the car, the best thing to do is to dump the DTC data .... it goes a long way toward helping pinpoint the problem.
As I said, I don't use AH or TC. I find them to be next to useless. But I do like ABS. I don't want to flat spot a set of $1,200 tires in a panic stop.
Search for posts by trussme or Bill Curlee with the keyword "EBCM" .... there are hundreds of posts on this issue.
Display the DTC codes on your DIC, you can/should search on thoose also. To display the codes, follow these instructions ...
https://www.corvetteforum.com/techti...D=26&TopicID=1
And to the new owner who says he turns off his TC and AH .... you might want to reconsider that for street driving,
they are great safety features in a car with high horsepower and the potential for the car to "get away" from you, especially at times such as wet roads, etc.
Chevy put them on the car for a reason, sure, if you are on a race track, turning them off may be fine (though that's why there is a COMPETITION MODE - even at the track AH is a cool feature)
but for street driving I recommend you leave the systems on. Search and you will find many threads where people say that the systems saved their azz ...
Since neither of these posters has listed his DTC data ..... what makes you think the problem is in the EBCM ?????
If it is a wiring problem to a wheel speed sensor, or the Steering Wheel Position Sensor is failing, then they've just spent money for nothing .... let's do a little diagnosing before jumping to a "fix" ....
Fair enough, just thought I'd throw that idea into the pot. I think the OP should always take the free/easiest fixes first before repairing a part.
For me, I went through 5 different ideas before I fixed it with the absfixer guy. I just scanned the replies and saw no mention of it.
Just Had Same Problem With My Z . It Was The Wheel Postioner Sensor. Which Is Located At The End Of The Steering Column Under The Dash ,driver Side. Part From Gm Cost $20.took Z To Gm For Install 1.5 Hr. Got The Z Back . No More Codes Or Problems. Do A Search In Wheel Postioner Sensor For More Info. Good Luck!!
C1287 - The SWPS (Steering Wheel Position Sensor) input is invalid
Given that it seems unlikely these would both fail at the same time, here's what I would recommend.
Step 1) Check the EBCM grounds and be certain they are clean. The EBCM is grounded at two points, G103, and G108. The EBCM provides the "ground" for the SWPS ... there is no seperate ground for it.
G108 is located on the right frame rail, next to G104, almost directly below the NEG battery cable.
G103 is located on the left frame rail, just behind G101, and about opposite the BPMV.
Step 2) After cleaning the grounds THOUROUGHLY, and checking the EBCM wiring connectors for corrosion, DELETE the codes from the EBCM using the DIC. Clear ALL codes from the car.
Step 3) Go out for a drive - 15 minutes or so, no need to do anything "aggressive", if the relay that sets C1214 is actually failed, the code will come back within seconds of your engine starting (and your foot is off the brake pedal).
Step 4) Check for codes at the end of the drive. Post here if there are any. If none ... very cool. If the C1214 is back, take a look at either replacing the EBCM with another from GM (which will eventually fail too) or sending in your EBCM to http://www.absfixer.com and getting the problem fixed once and for all.
I apologize that I haven't posted the DTCs yet. Just hasn't quite made it to the front of the priority queue yet.
-B
#33
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
two weeks ago I had the dreaded column lock rear it's ugly head. Had to tow the car to the local dealer where they replaced a couple relays and the column lock actuator. I was getting the ABS/AH codes at the same time but they couldn't get them to come back after the column lock issue was repaired. Is this stuff all related by any chance?
I located and cleaned the grounds on the frame at the front of the car by the radiator, are these the ones you are referring to?
Thanks for the assist, Clint
C1214 - The dreaded "BPMV control curcuit" relay .....
#34
Post the codes when you can and we'll look at them ....
#35
The ones on the front frame, drivers side, is the G103 location (by the radiator). G108 is on the other side (passenger) and further back, almost directly below the battery NEG cable.
The Corvette is different from most cars in that effectively it is a "plastic" body on a metal chassis. The reason this is important is that on your "average" car any electrical component can be grounded directly to the bodywork (metal) it is attached to. On the Corvette the ground has to actually be a wire that leads back to a location on the chassis. If these ground locations become corroded, or a wire comes off, then the component being grounded no longer works correctly, or works intermittently. With all the computers in a modern car, a bad or intermittent ground in a few components can cause all kinds of confusing and seemingly unrelated problems. Keeping the ground points clean on a Corvette helps a lot.
Also, voltage is important. The computers expect to see a consistent voltage level from the sensors and other devices they control. A weak battery can also cause seemingly unrelated and unexplained problems. Always check the NEG and POS battery cables when you are doing an oil change and be sure there are no signs of corrosion starting, or cables coming lose.
It seems unlikely the EBCM and the column lock issues are related, but certainly if you and/or the dealer cleaned ground points to address the column lock, that may have also cleared the EBCM issues. There are only a handful of groundpoints in the car, many are shared by numerous parts of the system.
It sounds like your EBCM is working OK now, DELETE those codes so you have a "clean" record, and keep on
Have fun out there ....
#36
Problem reared it's ugly head again this mornin...came scrolling across the DIC
Current Codes:
Module: 28 TCS Traction Control system ABS
Code: C1214 Sol Valve relay Contact or coil CKT Open
Historical Codes (had an 'H' next to them on the DIC):
Module: 40 BCM Body Control Module
Code: U1160 Loss of Communications with LDCM
Module: A0 LDCM Left Door Control module
Code: B2252 Key Cylinder Switch Fault DCM-LEFT
Code: B2284 Battery #2 Fault DCM-LEFT
Module: AC SCM Seat Control module
Code: U1064 Loss Of Communication with DCM (No SOH Message
Received -RFA
Module: A1 RDCM Right Door Control Module
Code: B2285 Battery #2 Fault DCM-RIGHT
I seem to have traction control problems in both my seat and in the rear wheels...
What say you?
Current Codes:
Received -RFA
What say you?
#38
Current Codes:
Module: 28 TCS Traction Control system ABS <-------- SEE BELOW
Code: U1160 Loss of Communications with LDCM <----- DELETE
Code: B2252 Key Cylinder Switch Fault DCM-LEFT <----- DELETE
Code: B2284 Battery #2 Fault DCM-LEFT <----- DELETE
Received -RFA <----- DELETE
Code: B2285 Battery #2 Fault DCM-RIGHT <----- DELETE
What say you?
Current Codes:
What say you?
I'd try cleaning the grounds at G103 and G108, then clearing the code and seeing if it comes back again. If it is intermittent, there is a chance that the grounding is the issue, as usually when the relay fails, it fails for good. Another thing you can try (after clearing the code) is taking the car on a quiet road and "exercising" the BPMV and the relay by making two or three stops that activate the ABS.
If the code won't clear, the best solution, in my opinion, is to ship your EBCM to
The site includes instructions on removing the EBCM (the car is driveable with the unit removed) and shipping it.
#39
Thanks for the information. At what level is the AH/TC and ABS functioning now? Not at all? Also, what's the skinny on the functionality of the relay? (or a link will work )
#40
ABS - Anti-lock Brake System
TC - Traction Control
AH - Active Handling
DRP - Dynamic Rear Proportioning
RSC - Rear Stability Control (2001 and later)
The EBCM continues to monitor/control your MAGNASTEER system, as it uses a different solenoid to control that system.
Basically you are driving a car from the 1960 era .... you have a brake system that works, but your foot is completely in control. There are no "nanny" aids such as ABS to come to your assistance in an emergency. Another way to look at it .... when/if you remove the EBCM and send it to absfixer ..... the car will drive the same (almost - steering effort may feel different) with the EBCM removed as it does today with a "disabled" EBCM. ALL of the above functions are COMPLETELY disabled.
The EBCM is basically a computer, it has no "mechanical" capabilities. The BPMV is a mechanical device that is able to either increase pressure in a brake line, or decrease pressure in a brake line, but it has no "brain" within itself that decides when to change the pressure in a brake line. The EBCM is the "brain" that controls the "dumb" BPMV. The C1214 simply indicates that the EBCM no longer has the ability to control the BPMV. Once the EBCM realizes it cannot control the BPMV, it sets the C1214 and "disables" (shuts off) all of the functions it controls through the BPMV.
