Car to buy..battery/electr. work on VIN search shows up
A 98 C5 I am considering buying shows in one month in year 2000
a tow a new Battery and some electrical work on the chevy VIN search...
Would you think this had the leaking battery problem ?? and could
that be causing more problems now 7 years later or was what was done
done..and should no longer be a concern.....ok..thanks alot..
10/22/2001
C0183 - REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE 28720 miles
10/17/2000
C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 21437 miles
08/18/2000
N0110 - BATTERY - ONE - REPLACE 19760 miles
08/02/2000
C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 19245 miles
07/31/2000
N3460 - SOLENOID - STEERING COLUMN BRAKE TRANS SHIFT INTERLOCK - R 19245 miles
07/31/2000
N2320 - SWITCH - IGNITION - REPLACE 19245 miles
07/31/2000
T2020 - TOWING 19245 miles
07/19/2000
N2355 - SWITCH - MULTIFUNCTION (INSTRUMENT PANEL) - REPLACE
18973 miles
10/22/2001
10/17/2000
08/18/2000
08/02/2000
07/31/2000
07/31/2000
07/31/2000
07/19/2000
18973 miles
I own a 98 myself and the problems with the Delco battery are well known. If the battery has been replaced within the last year or so, I wouldn't worry about that. I see the window regulators were replaced, and again that is a common problem that is usually resolved by holding down the window switch and slamming the door closed. The motor gets stuck sometimes and slamming the door will free it up. Looks like the column lock bypass was done which is a factory recall. So, I see no major problems, but have a mechanic that is familiar with Corvettes take a look at it, or find a forum member in your area to look at it with you. Enjoy....
Good luck.
