[Z06] Rear window defroster not working...help pls
My rear window defroster stopped working. Can someone tell me what fuse I should be looking for? I checked the fuse box in the engine bay and didn't see anything that specifically say "defroster". Unfortunately, I don't the manual. Any help would be awesome.
Fuse 48 and the fuse box is underneath your passenger side kick panel (inside the car).
Also look at the wire that connects to the grid on the window. It's very common that it breaks off.
Put a milti-meter across the 2 connectors of the window element to see if you have an open circuit.
