[Z06] 371 rwhp on 2001 ZO6 just bolt on
Re: 371 rwhp on 2001 ZO6 just bolt on (01redcoupe)
You have shared this info before. :rolleyes: Please first show before and After Dyno's... If you would like... Fax them to me, and I will scan them, and post them for youl. My Fax# is 480-348-9003
Who's Headers are you using? Belanger, TTS, TPIS B&B? Who's?
Typical Z-06 car's tested at TechnoDyne, and ProDyno were in the 340 RWHP Range, Stock. (Mine was 343 with 600miles on it) @ Technodyne. So 50+ Hp would be 390 Range! :eek:
If you figure 10 RWHP for an intake, 20 RWHP for Headers, and no cats & Cat Back, I am also at 370... how is this any different? I haven't mentioned the computer... but lets throw in another 5 for that too!
Is this price installed?
Thanks!
Dave
Thanks for the feedback!
Dave
Thanks!
Dave
Dave
Cruising
Re: 371 rwhp on 2001 ZO6 just bolt on (Dave Schotz)
Only supporting vendors may make offers on the forum.
thanks,
MyC5
[Modified by MyC5, 7:59 PM 8/9/2001]
thanks,
MyC5
Re: 371 rwhp on 2001 ZO6 just bolt on (Nate@xtreme)
I did receive the Dyno Sheets... but unfortunately no graphs, and I received them By Fax, not Email So I now have to scan them to post them. :(
The read outs I got are just the RPM numbers in this format...
RPM POWER TORQUE
500 40 50
600 45 55
etc..
So... yes if you compare the two readouts, there is about a 49hp & 43 Tq improvement.
However the 322 RWHP 'Stock' dyno was done on January 29th, with a Correction factor of 1.03
The 371 RWHP (368.6 on the sheet) was done on AUGUST 6th! with a correction factor of 1.07!!!
Now, this doesn't mean it isn't possible, but this is about the furthest from a controlled environment you could get!
Also, when you get 500 RPM increments, the Peak #'s can be plus or minus a few... so I am sure if we saw the actual graphs... it would indicate close to 371.
However, to claim 50hp, and have test 6+ months apart... prolly not the most accurate...
I would love to see a before & after done within the same day. (atleast the same week) ;)
Peace,
Dave, and it's SCHOTZ! ;)
RPM POWER TORQUE
500 40 50
600 45 55
etc..
Peace,
Ask, and you shall receive.
I just received the fax from Verdone & B&B with the actual Dyno Graph.
Dyno Run done 1/29/01 321.7 RWHP & 321.9 RWTQ Mods (None, Stock Baseline.)
Dyno Run done 2/2/01 331.8 RWHP & 327.1 RWTQ Mods (B&B Cat Back & Computer Mod)
Dyno Run done 4/4/01 355.9 RWHP & 352.4 RWTQ Mods (B&B Cat back & Computer Mod & Headers)
Dyno Run done 8/6/01 368.8 RWHP & 364.3 RWTQ Mods (B&B Cat Test & computer Mod, & Headers) I am guessing 'Cat Test' means no cats.
As you can see there is plenty of questions.
1.) According to these numbers the Cat-Back, and CPU gained about 10 RWHP & 6 RWTQ. Not bad.
2.) B&B has never claimed 20+ RWHP & TQ for it's headers, but these numbers would say otherwise.
2.) Generally on a good Day... an Off-Road pipe would be worth 5-10 RWHP at the Most, these show 13 RWHP.
I think a lot of these variances have to do with the significant time in-between tests.
However... to sum up a few things, the Graph is SAE Corrected, which is a good thing!
And there is a definite improvement with each stage. I love the detailed testing in between mods, just wish they were done a bit closer together.
I would say that 35-40 RWHP can be achieved with this combination, in normal circumstances.
My .02
Dave
Joe, I hope you have found my comments independant, and fair.
Peace
My .02
Dave
Peace
