Techron complete fuel system cleaner 20oz BOGO
Advance auto parts has them on sale!!!
Techron concentrate plus complete fuel system cleaner 20oz
BUY ONE GET ONE FREE
$13.99
$13.99
The following 5 users liked this post by Sunwarrior:
CorvetteBrent (08-31-2020),
doublenut9 (08-31-2020),
jcgunn (08-31-2020),
Mickeyrx70 (08-31-2020),
RtStuf (09-01-2020)
Received 1,864 Likes
Thanks for the heads-up, OP. Techron is good stuff.
Received 3,111 Likes
St. Jude Donor '21-'22
JimHarris4 (09-04-2020)
jbelant (08-31-2020)
Received 19,233 Likes
'20-'21-'22-'23-'24
Thanks for the notice, I need to replenish my supply.
I'm looking at the techron concentrate plus at Walmart in person, this store it's $4.94 and it's 10 oz.
Back of bottle says treats up to 15 gallons, anyways that sale sounds like a good deal.
If you use too much Techron, it can damage your fuel tank lining.
How many oz do you use for each treatment?
The manufacturer recommends using one ounce per gallon. I believe the size of the gas tank changes depending on what year your car is, but one treatment should be 18-19 ounces based on fuel tank size. For simplicity. it's probably okay to just use an entire 20oz bottle as long as you don't use it too often.
Pacha's Z06 RF (09-03-2020)
I don’t know if this is Techron/fuel-sender related - but I have watched with interest as I have filled my car up from empty with the ignition - on the gas gauge moves smoothly to about half tank and at 8 gallons it sits there for quite a while and then suddenly jumps up to 11 and moves up to full - I guess this is just the result of having two separate tanks?
