Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-30-2005, 10:05 AM   #1
davidp
CF Member
Default 2003 ZO6 Tire Size
I know this is probably like beating a dead horse, but here goes.
What tire size can I upgrade to (the largest) front and rear on stock ZO6 wheels, without having any clearance problems?
Thanks in advance
davidp is offline   Reply With Quote
Old 03-30-2005, 10:39 AM   #2
john anderson
Junior Member
Default tire size
I've the exact same question, but don't have the answer. I don't see the need to duplicate your inquiry. When and if you get the answer would you pleas e-mail me at jaflamethrower@aol.com.
Thanks, Flame Thrower!
john anderson is offline   Reply With Quote
Old 03-30-2005, 10:50 AM   #3
OutlawDon
CF Senior Member
OutlawDon's Avatar
305/35/18 to 315/30/18
OutlawDon is offline   Reply With Quote
Old 03-30-2005, 11:34 AM   #4
l2vette
CF Senior Member
l2vette's Avatar
Quote:
Those are not the stock wheel sizes.
l2vette is offline   Reply With Quote
Old 03-30-2005, 03:21 PM   #5
dtwalkerfl
CF Senior Member
dtwalkerfl's Avatar
315/30-18's will give you a shorter tire than the stock ones in rear (25.44 diameter compared to stock 26.13 diameter)
305/35-18's will give you 26.41 diameter and will effect your speedo slightly.
He didn't go into front sizes.
I am upgrading to 275/35YR18 fronts and 295/35YR19 rear (BFG G-force T/A KDW-2 tires) on new C6 wheels. The problem is in the rear wheel offset. The C6 rears have a +79mm offset and the stock Z06 rears are +58mm. I had to order spacers specially machined to move the wheels out on the rear. The fronts are the same stock offset (+56mm).
dtwalkerfl is offline   Reply With Quote
Old 03-30-2005, 09:04 PM   #6
OutlawDon
CF Senior Member
OutlawDon's Avatar
Quote:
Stock wheel sizes?? He wasn't asking about the wheel sizes.
He asked for the biggest tires possible and I gave him suggestions.
Old 03-30-2005, 10:02 PM   #7
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I think the Outlaw gave a size upgrade range....
Ron
Dr.Ron is offline   Reply With Quote
Old 03-30-2005, 11:39 PM   #8
davidp
CF Member
Hey dtwalkerfl, Thanks, would the results of the 305's on the speedo be minimal?
Thanks Again
Old 03-31-2005, 01:09 AM   #9
OutlawDon
CF Senior Member
OutlawDon's Avatar
305's will be fine. Won't screw with the ABS/TC sensors. Speedo will just be slower than actual speed, but very very minimal. Less than 2% difference.
Old 03-31-2005, 10:05 AM   #10
tlaselva
CF Senior Member
tlaselva's Avatar
Below is a post for upgraded rims and tires from a experienced racer on this forum.
Sorry, forget his screen name....
Whomever you are, I hope you don't mind...
I recommend:
305/30x18 on 10.5x18 with +0.25" offset for the front
and 315/35x17 on 11x17 with +0.25" offset in the rear.
This neutralizes the handling, increases front grip, increases front turn in, decreases braking distance, increases front steering response and modulation, reduces understeer and stabilizes the flex of the front side wall.
It also increases rear traction under hard acceleration and cornering allowing the car to "squat" better.
This results in higher corner entry speeds, mid corner speed and corner exit speed.
tlaselva is offline   Reply With Quote
Old 03-31-2005, 04:43 PM   #11
Monnie
CF Senior Member
Monnie's Avatar
Send a message via AIM to Monnie
Quote:
Originally Posted by tlaselva
Below is a post for upgraded rims and tires from a experienced racer on this forum......
I recommend: 305/30x18 on 10.5x18 with +0.25" offset for the front
This neutralizes the handling.........
Would this be BETTER than stock? Or is this just the best option ONLY if you wantt o upgrade??
Monnie is offline   Reply With Quote
Reload this Page 2003 ZO6 Tire Size
Tags
18, 2003, 2004, beast, c5, corvette, front, inch, rear, requirements, size, tire, tires, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
