Only $12.95 For Corvette C5 Tail Light Seals
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Only $12.95 For Corvette C5 Tail Light Seals using C5OFF code
Tail light seals for all C5 Corvettes (1997-2004)
Available here : https://www.southerncarparts.com/cor...eals-p-41.html
Special : $12.95 using code C5OFF
What is the dreaded drip?
The dreaded drip is when you just finish washing and drying your Corvette, everything looks awesome.....You walk around your pride and joy for that one last look and there it is, the DREADED DRIP
It is the water that collects in your tail lights (because GM did not put a seal between the taillight and the body) and then drips out and down the rear bumper 5-10mins AFTER you finish drying your car. It is also the water that collects in the tail lights and attracts all the road grime when you first take your Corvette for a spin after a good washing. (picture below are the seals installed on a C6)
Southern Car Parts Tail light seals solve the problem FOREVER, guaranteed!!!!! Our tail light seals take less than 7 minutes to install, come with instructions, and are pre-cut to be and exact fit every time. Only tools needed to install them is a T15 Torx head and window cleaner. No gluing as they have a self-adhesive backing.
The seals are made from a high-quality rubber that is UV resistant, temp resistant, and water resistant....THE SEALS ARE GUARANTEED FOR THE LIFE OF YOUR CAR. If they ever rot, crack, tear, or fade we will REPLACE THEM FREE OF CHARGE! You will NEVER see the DREADED DRIP again!!!!!
Supporting Vendor
Retail : $17.95
