Throttle body coolant bypass. Yeah or Neah?
Have some tubing left over from the LS6 intake swap just completed. Should I bypass the coolant from the Throttle body? Any adverse effects? How much does the coolant actually effect the air temperature?
Probably no effect, unless you live in a cold & damp area, then the bypass maybe a problem with icing. Otherwise it's a "feel good" mod.
I noticed you live in Dayton OH. You get enough cool weather up there to possibly run into throttle plate icing on cool damp days. It doesn't have to be below freezing, just about 40 deg. and the low pressure area just behind the t-plate can form icing. The composit intake doesn't transmit heat like the old cast iron and cast aluminum intake manifolds of days gone by, so that mod is about useless anyway.
zo6vettepilot
zo6vettepilot
