Old 03-06-2015, 05:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Weights, measurements, ratios, strengths, etc
Old 01-20-2005, 05:46 PM
  #41
Traffic Hater
Traffic Hater's Avatar
All I can say is thank you for all of this information.
I thought I knew a lot about my car!
This is the post of all posts!
Thanks!
Old 01-22-2005, 09:54 AM
  #42
PewterCloneZo6
PewterCloneZo6's Avatar
Default Thanks!
I was about to go mad over my Oil pressure sensor! This article really helped loads!
Old 01-24-2005, 04:04 PM
  #43
Oldad
Support Corvetteforum!
Oldad's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '07
Required reading-Great Info
Old 01-25-2005, 08:44 AM
  #44
Alex1217
Alex1217's Avatar
St. Jude Donor '08-'09
I'm curious to know how much the stock front rotors weigh. I know that the rears weigh 13.75 lbs. If anyone has this info, please post it up so we can update it. Lefteye has the Napa rotor weight posted but I'm not sure if this is the same as the stock ones.
FYI these are the weights of the Baer Eradispeed rotors posted by Evil-twin:
Front:
14.0 lbs - 2pc
22.5 lbs - 1pc (solid cast)
Rear:
15.0 lbs - 2pc (new version) 14 inches
14.0 lbs - 1pc (solid cast with thicker fire path)
So, if anyone whose currently working on their brakes or have their front stock rotors around, could you post up their weight? Thanks!
Old 01-25-2005, 09:48 PM
  #45
leaftye
leaftye's Avatar
Thanks Alex!!! I should've kept checking that thread, but Evil-Twin thought they weighed more than regular rotors, and it seems he's wrong. I have some caliper work to do soon, so I'll be able to weigh some used rotors. They've been used, so it won't be full weight. I've heard some people have bought Napa rotors and GM rotors, and they had the same part numbers in it, so it seems like they are the same parts. I'll weigh it anyway, if only to know how much they wear out. The calipers are lighter than I thought, so it may not be worth going to aftermarket calipers. I'll post that info in the next update. If aftermarket calipers aren't lighter, I'm going to get some OEM calipers coated ($100 a pair) and be done with brake upgrades....well, I do have an experiment I want to try... Check post #6 to see what else is coming.
Eugene
Old 01-30-2005, 10:19 PM
  #46
charlieb
charlieb's Avatar
Incredible info, that's what this froum is about. Thanks!!!
Old 01-31-2005, 01:22 PM
  #47
Vette1999Hardtop
Vette1999Hardtop's Avatar
Great information Thanks
Old 02-09-2005, 01:38 PM
  #48
Blade1
Blade1's Avatar
Great thread to bookmark, thanks!
Old 02-10-2005, 10:39 AM
  #49
mcronec5
mcronec5's Avatar
Cruise-In VII Veteran
That was a nice post. Thanks for putting it together. Here is everything I know about the C5. Its fast, and it looks better than Mustangs.
Old 02-12-2005, 07:31 PM
  #50
Allthrottleandsomebottle
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
NCM Ambassador
Here are some more tire/rim weights, all combos include oem 1997-2000 wheel sensors.......
Bridegstone expedia S-01 345/35/18 9/32 tread 37lbs
OEM runflat 245/45/17 8/32 tread 29lb
BFG G-force drag radial 345/30/18 30
Topline 18 x 10.5 +58mm offset rims w/ 275/35/18 BFG G-force TA drag radial 53
HRE 18" x 12 545 w/ 345/30/18 BFG DRS 57
HRE 18 x 9.5 545 w/ clear center +58mm w/ 275/35/18 BFG KDWs 52
HRE 18" x 12 545 w/ 345/35/18 EXPEDIA S-O1 9/32 tread 64
HRE 19" X 10" 545 w/ Yoko 295/35-19 AVS sport non-runflats 5/32" TREAD 58
OEM runflat 275/40/18 worn to wear bars 29
Do you need 01' Z06 OEM leaf spring:
front
rear
Old 02-13-2005, 12:47 AM
  #51
leaftye
leaftye's Avatar
Steve, thanks for the help! Weights for the Z06 springs would be great! I still need to weigh my Z51 and VBP springs. I've heard a couple times that the VBP springs are lighter, but VBP denies that their springs are lighter than stock. I'll know if the rumors are true or not very soon.
Old 02-13-2005, 04:49 PM
  #52
Cruise-In V Veteran
NCM Ambassador
Here ya go.
2001 ZO6 springs:
Front, "AY", 22178729, 8lbs, 15.5 oz.
Rear, "RJH" 221880???, 12 lbs 3 oz.
I will post other weights as I do them.......
Old 02-21-2005, 07:50 AM
  #53
phils C5 vette
phils C5 vette's Avatar
St. Jude Donor '12-'13-'14
ttt
Great thread
Old 02-25-2005, 08:57 AM
  #54
mbeeman350
mbeeman350's Avatar
St. Jude Donor '03-'05-'06-'07-'09
Being new to C5's this is a great info...thanks Leaftye
Old 02-25-2005, 10:53 AM
  #55
saalanghae
saalanghae's Avatar
Great post and info!!!
Old 02-26-2005, 03:46 PM
  #56
leaftye
leaftye's Avatar
9.1 lbs -- VBP 736 lb front spring with rubber isolators, without adjusting bolts, and missing one of the thread inserts
9.9 lbs -- VBP 850 lb rear spring with rubber isolators, without adjusting bolts
Old 02-27-2005, 03:24 PM
  #57
AllTaken
AllTaken's Avatar
Can we have a list of all the differences between '97-'04 C5s? I've always wanted to know, plus different recalls etc for each year, etc. and what each years weaknesses were.
To Weights, measurements, ratios, strengths, etc
Old 02-28-2005, 01:39 PM
  #58
leaftye
leaftye's Avatar
AllTaken, I'd be happy to put recall (TSB) information here, but the rest of the information isn't really inline with my intent of this thread, so if anything, I'll post a few links to good pages and threads. The weaknesses of each year is a little harder for me to do since they made a lot of production line changes, and it'd take quite a database for me to do justice with the topic. By reading thru the thread, and the links, you can get a feel for which years have problems, but it's still too much for me to comprehend without making a database.
My next update should be in around 1 1/2 months. Keep in mind that the updates will match my intent for this thread is to have a resource that helps fully utilize the Corvette, especially in regards to maintenance, with the ultimate goal of only having to research this thread to build a strong & light race car.
Old 03-08-2005, 02:20 PM
  #59
ExRedRacer
ExRedRacer's Avatar
Received 1,029 Likes on 549 Posts
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Great post. Thanks for all the info. I'll be referring to it often.
Old 03-18-2005, 01:56 PM
  #60
leaftye
leaftye's Avatar
Default Favorite links
I moved this information to the top...
Quick Reply: Weights, measurements, ratios, strengths, etc
