Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C5 Corvette: General Specifications and Information
Important information to help you understand your Corvette.
Weights, measurements, ratios, strengths, etc
#241
There will a short quiz later, my main issues are the ashtray and cup holder. I got a beter ashtray but it fits in the cup holder and there's one vice versa, wt*e.
#242
I've learned that it was added to the DIY sticky in the Tech section, post 110,
http://forums.corvetteforum.com/c5-t...l-in-here.html
Not lost or unloved just consolidated all in one place
#244
Please remove the UTQG ratings from the tires you listed, the UTQG are only to be used to compare a tire rating of the same manufacture ie: kumho to kumho. Not to be used in the list form that you used for other brands in a comparison.
#245
MD Events Coordinator
Wow
Thanks for the information. I now know more about the car that I just purchased than I spent two months researching. You guys are the bomb!
#248
Lepus-temperamentalus
Please correct the link on the O/P about the white paper regarding shaky brakes.
That white paper is now found at:
http://www.stoptech.com/technical-su...nd-other-myths
#252
I have a 02 Z06 with a Twin Turbo and Methanol injection. I found it STRANGE that the AC only worked on Defrost. Upon investigating, I found the EXACT evidence described of a "LEAKING BATTERY".
Can anyone give me some pointers as to the most "Inexpensive" way to fix the AC issue? It is STAYING on DEFROST...
I was thinking about adding a Vacuum pump or something might be the easiest way to supply the necessary vacuum.
What do you think?
Thanks in advance,
What do you think?
Thanks in advance,
#254
hi I own an 97 c5 ls1 6speed corvette and for some reason cannot get into gear clutch allows me to start the car then I can freely go thru the gears why is this?
#255
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Gudmundson
I recommend that you create your own post on your drive train problem. You will get a LOT more looks, responses and assistance.
I will look for your new post and provide assistance.
Bill
Bill
#258
There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment behind the carpet and on the side of the car. Not that it really works well.
What is this?? I am curious!
#259
Width between motor mount holes?
I am looking t swap in an LS series engine into my truck. I don't have an engine yet, but thanks to a helpful member here I have a set of C5 mounting brackets. I need to determine the width between the mounting holes for the brackets so I can work on fabbing some mount adapters.
I have searched and looked at a number of frame drawings but don't see this info. Thanks for any help.
EDIT
I'd still like the C5 dimensions if possible.
I found the below thread. While the pictures and links are out of date, one post said the measurement is 17.25" or so.
http://www.chevytalk.org/fusionbb/sh...hp?tid/211262/
I found the PDF referenced in an archive, and have attached a copy. It has several LS1 engine dimensions.
EDIT
#260
If anyone is looking into replacing axles: My dealer quoted me $250+ per side for a replacement. I ordered re-manufactured ones from Cardone, cost was like $65 per side and they met or exceeded OE specs.
