Carbon Drive shaft Christmas Sale from LG Motorsports
Old 12-07-2004, 01:10 PM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Carbon Drive shaft Christmas Sale from LG Motorsports
We are offering a Christmas Sale price on the LG Motorsports Carbon Drive shaft.
This is the same Drive shaft that many teams are using in the SCCA World Challenge series with no issues.
It is the same shaft that was in my car with 535rwhp 482 rwtq at the drag stip that broke 3 rear ends from too much tire bite, but never even phased the drive shaft.
The Corvette drive shaft is nothing more than an "extended" input shaft from the engine to the front of the Transmission. This shaft will turn at engine RPMs and the stock drive shaft will "whip" like a jump rope which is what causes the rubber coupler joints to crack or break.
We also offer a billit coupler that can be used on one end for extreme racing or very high hp cars.
This drive shaft will also eliminate the vibrations that come from the stock drive shaft deflection.
Christmas Sale Price= $1095. for the carbon fiber shaft ( 1/2 the weight of the stock shaft and 100 times the stiffnes.
The Billet coupler is sale priced at $99.95
Thanks and Merry Christmas.
Lou Gigliotti LG Motorsports
Race quality Carbon Fiber drive shaft:
Billet coupler:
Old 12-07-2004, 01:13 PM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
Lou!! You are Killing me Here!! I have been on the fence regarding this mod... Man, I will have to think about this special real hard!!
VR
Old 12-07-2004, 02:05 PM
SteveL2
SteveL2's Avatar
Gonna be a little obvious wrapped under the tree.
But, a sale is always nice.
Old 12-07-2004, 02:32 PM
blackbelt
blackbelt's Avatar
must keep credit card away. Too many sales at once I am dying over here!
Old 12-07-2004, 03:15 PM
more carbon
more carbon's Avatar
is this for high hp cars only,or does it benifit a mild heads cam car???? do you need to drop the rear for install????
Old 12-07-2004, 06:19 PM
LG Motorsports
This is for any car that ever runs up the rpms. The stock drive shaft has a plastic/composite donut on the shaft to limit the amount of "swing" that the stock shaft has.
The "Jump rope" effect is common with rpms as well as high hp launches.
The drive shaft turns at a speed equal to the engine rpms in every gear so it sees these rpms every time the car is run through the gears.
It not only is stronger it is truly straight with no deflection in this application.
We rev around 7500 in the World Challenge race car and ran the same drive shaft all season long.
Then we used the same shaft at the drag strip for the 140 mph 1/4 mile run where we destroyed 3 rear ends that day but the drive shaft was perfect when we checked it out.
The only cars that won't benefit from this drive shaft are the show cars that never drive
Lou Gigliotti LGM
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Old 12-08-2004, 12:05 AM
Wisdom
Wisdom's Avatar
"It is the same shaft that was in my car with 535rwhp 482 rwtq at the drag stip that broke 3 rear ends from too much tire bite, but never even phased the drive shaft."
Hmmmm, what does a new one cost?
Old 12-08-2004, 12:08 AM
DirtyRed
DirtyRed's Avatar
Would this fit an A4?
Old 12-08-2004, 12:57 AM
LG Motorsports
6 to 8 weeks before we have the A4 shafts.
LG
Old 12-08-2004, 06:32 PM
LG Motorsports
I will be out of town for 2 days, so if you have any questions feel free to call one of our salesman and they can fill you in.
LG
Old 12-08-2004, 06:51 PM
Dope
Resident moron
Support Corvetteforum!
Dope's Avatar
Is it really half the weight? I could have sworn you originally said the weight difference was only 1lbs or so. Unless the stock shaft weighs 2lbs
Dope
Old 12-09-2004, 12:25 PM
gmblack3
gmblack3's Avatar
Lou, Will this sale still be going on at the next week? I hope so...
Called LGs shop today and they said the sale was on till the end of the month.
Old 12-11-2004, 10:55 AM
ToplessTexan
ToplessTexan's Avatar
Cruise-In II Veteran
What are people doing about balancing the whole assembly?
Old 12-11-2004, 12:10 PM
Z_fox
Z_fox's Avatar
I had my CF DS installed when they did the Excedy clutch and no balance was necessary that I am aware of. I feel no vibrations and the engine seems to rev up and down quicker than before but not sure what the twin disk may have contributed to that.
HTH
Old 12-11-2004, 01:02 PM
Red C5
Red C5's Avatar
What does it weigh? I read half of the OEM but what's that?
Old 12-14-2004, 09:30 PM
ToplessTexan
No more thoughts on balancing?
Old 12-14-2004, 09:49 PM
LG Motorsports
There is no problem with balance since the carbon shaft is checked for balance at the manufacturer. It is not only straight and true but almost perfectly balanced.
We have found most stock Aluminum shafts to be slightly bent when we remove them. The center "disc" that is there to limit the deflection is usually rubbed on only one side. That means that the aluminum shaft has a memory and flexes in the same direction each time after the first time.
Plus, how balanced could a stock shaft be when it flexes.
Lou G
To Carbon Drive shaft Christmas Sale from LG Motorsports
Old 12-14-2004, 09:58 PM
LG Motorsports
Dope
Just weighed one.
Stock = 5.26 pounds
Carbon = 4.56
Difference = .7 pounds
You were correct. It was closer to the original estimate of 1 pound.
The benefit does not come from weight reduction but from it being stiff, straight and strong enough to resist the "jump rope" effect.
sorry for the confusion.
LG
Old 12-14-2004, 10:10 PM
Red C5
Red C5's Avatar
Is there a video of the "jump rope" effect? I'mhaving a hard time visualizing this happening, sounds bad. Is this a commonly broken part? Don't think I've read a thread about broken drive shaft yet.
Old 12-14-2004, 10:44 PM
Rollin Black
Rollin Black's Avatar
Put one aside for me Lou.
I will be ordering it, an aluminum driveshaft coupler, and a few other items soon. Gotta help Santa out
Thanks for the great products!
Perry
Quick Reply: Carbon Drive shaft Christmas Sale from LG Motorsports
