Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2004, 06:56 PM   #1
Jman
CF Senior Member
Jman's Avatar
Default LUk Pro Gold Clutch and lightweight flywheel
Well I've decided on a clutch. I'm going to go with the LUK Pro Gold series kit with the lightweight flywheel. Many people have said how good they are. I sure hope so, they're pretty expensive!
Jman is offline   Reply With Quote
Old 11-11-2004, 07:26 PM   #2
Ikester
CF Senior Member
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Ikester's Avatar
Send a message via AIM to Ikester
Quote:
nah, Exedy is expensive. (1500+) LUKs go for 700 and change complere with balanced flywheel. thats what im going for.
Stock pedal pressure but can hold 450rwhp+...cant go wrong!!
__________________
2000 Coupe MN6- ECS LS3|TEA ported AFR 205s|LG G5X1E Cam|ported FAST 90/90|Kooks Headers|Mantic ER2 clutch|4.10s Black Sheep Squadron Member
496RWHP / 471Tq
Ikester is offline   Reply With Quote
Old 11-12-2004, 12:47 AM   #3
Viprklr
CF Senior Member
Viprklr's Avatar
Send a message via AIM to Viprklr
I'm happy with my LUK Gold set-up. I'm at 415rwhp and it holds the power and is SMOOTH.
Matt
__________________
2007 VY Z06 2LZ -- Kooks Headers, Corsa Exhaust, Ported TB/Intake, Killer Bee
Previous Vettes:
2006 Black Coupe -- SOLD 6-28-08
2000 Pewter Hardtop -- SOLD 3-14-06
Viprklr is offline   Reply With Quote
Old 11-12-2004, 02:06 PM   #4
Jman
CF Senior Member
Jman's Avatar
Is there a horsepower or torque rating on the LUK Pro Gold series clutches? I haven't seen any actual numbers.
Old 11-12-2004, 02:31 PM   #5
Umrswimr
CF Senior Member
St. Jude Donor '05
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
Send a message via AIM to Umrswimr
Be sure to post up a nice review once you get it done. My clutch will need to be replaced here in the next few months and the Luk & AL flywheel is my #1 candidate.
Umrswimr is offline   Reply With Quote
Old 11-12-2004, 04:06 PM   #6
ScottN
CF Senior Member
St. Jude Donor '05
Support Corvetteforum!
ScottN's Avatar
I have the LUK plus aluminum flywheel. I abolutely love the shift/pedal action. Here's a link to some info on the clutch. Link to LUK info. Read the info for the stage 2 clutch and you'll see it is rated to 575. I think that is flywheel hp but don't know for sure.
I would warn you to investigate the aluminum flywheel. It should give you some performance gains but I have noticed drawbacks. The aluminum flywheel is noisier and requires more rpms to take off in first gear. Not a lot more rpms but its noticeable. Also, in tight driving situations (like the stop-n-go getting in/out of a parking lot) where you might ride the clutch a little bit, the rpms can surge/rev a little bit.
I can deal with additional rpms on take-off but have really tired of the noise and surging. I plan to switch my LUK to the steel flywheel in the spring. Others have said they have not noticed the noise/surge problems.
If you can, see if you can go for a ride with someone who has a LUK plus aluminum flywheel and get some firsthand experience. I did not and reget getting the aluminum flywheel.
ScottN is offline   Reply With Quote
Old 11-12-2004, 04:09 PM   #7
rodknock
CF Senior Member
rodknock's Avatar
Just ordered LUK stage 2, have you had any balance problems with the aluminum flywheel?
rodknock is offline   Reply With Quote
Old 11-12-2004, 04:28 PM   #8
ScottN
CF Senior Member
St. Jude Donor '05
ScottN's Avatar
Quote:
Not that I have noticed. I haven't had any problems with excessive vibration. Just increased noise.
Old 11-12-2004, 04:54 PM   #9
TT_Vert
CF Senior Member
Send a message via AIM to TT_Vert
is the pedal effort similar to stock?? any sticking clutch pedals with these? How about clutch chatter?
dave
TT_Vert is offline   Reply With Quote
Old 11-12-2004, 05:11 PM   #10
ScottN
CF Senior Member
St. Jude Donor '05
ScottN's Avatar
Quote:
dave
The pedal action is very smooth. Very little effort required and no sticking. LUK is the same company that built the OEM C5 clutch.
There is additional clutch noise/chatter due to the aluminum flywheel. At least that is my opinion. Its not excessive but it is noticeable to my 34 year old ears. If you had the stereo turned up or one of the louder exhausts, you might not hear it.
I think a lot of people would be willing to trade-off the increase in noise for the increased HP. I was told the aluminum flywheel would add 20 HP at the flywheel. I can't verify that increase because I had too many other mods done at the same time. Although, I think 20 HP sounds a little generous.
Old 11-12-2004, 05:40 PM   #11
TT_Vert
CF Senior Member
well i hope its not like the z06 clutch. I have a 5k mile z06 clutch w/ slave and z06 master that sticks already. What kinda noise are you referring to? Id rather have no noise and no HP gain personally./
Dave
Old 11-12-2004, 05:40 PM   #12
TT_Vert
CF Senior Member
well i hope its not like the z06 clutch. I have a 5k mile z06 clutch w/ slave and z06 master that sticks already. What kinda noise and chatter are you referring to? Id rather have no noise and no HP gain personally./
Dave
Old 11-12-2004, 06:14 PM   #13
ScottN
CF Senior Member
St. Jude Donor '05
ScottN's Avatar
Dave
Explaing noises is hard becasue its so subjective. I suppose I'd say its more like a ticking noise. I notice it most when I let off on the gas pedal around the 2500-3500 rpm range. I asked Carolina Clutches and they said you can get a billet flywheel for the LUK Pro Gold and avoid the chatter. I think you have to get the billet flywheel balanced where the aluminum flywheel is prebalanced...but don't quote me on that.
Old 11-15-2004, 03:57 PM   #14
BLACKTOP2000
Junior Member
BLACKTOP2000's Avatar
Default Luk
I have the gold series works great 415 rwhp
BLACKTOP2000 is offline   Reply With Quote
Old 12-07-2004, 10:14 AM   #15
ericdwong
CF Senior Member
ericdwong's Avatar
Any long term reports on the longevity of these clutches? Did anybody need to "adjust" the clutch?
ericdwong is offline   Reply With Quote
Old 12-07-2004, 11:39 AM   #16
curtbriggs
CF Senior Member
curtbriggs's Avatar
[QUOTE=ScottN]I was told the aluminum flywheel would add 20 HP at the flywheel.
curtbriggs is offline   Reply With Quote
Old 12-07-2004, 12:38 PM   #17
sprinter
CF Senior Member
sprinter's Avatar
Im at ~500rwhp and no problems yet with my standard clutch. Although, I dont do hard launches with the Nitrous. Not sure but I think my '01 C5 has the same clutch as a Z06.
sprinter is offline   Reply With Quote
Reload this Page LUk Pro Gold Clutch and lightweight flywheel
Tags
aluminum, c5, clutch, clutches, corvette, corvettes, flywheel, gold, kit, lightweight, luk, making, noise, pro, reviews
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Heads/Cam or Supercharge it? BRAD54 C5 Z06 Discussion 42 08-06-2005 08:33 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
