Valve spring help...Please
1 Post
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
New cam installed yesterday! Fairly easy install until I got to the springs. The spring compressor I have (pic below) will not compress both springs (dual springs) Without buying the rocker type recommended by Thunder racing, LG Motorsports, what tool have you guys used? Many thanks, I am now at a point where I can't do anything else.
my spring spring tool..won't work
cam and underdrive pulley installed
Thunder racing tool $129.00 !!!
That spring compressor will work just fine. Just use it as if there isn't an inner spring and when the main spring is squeezed, just push down a bit and the inner spring will compress, its a pretty light spring. I used the exact same compressor for mine and it worked great.
1 Post
Cruise-In V Veteran
MTWallet...That's what I did, but could hardly compress and install locks...maybe it's because I'm using comp 921 dual springs? they are stout!
Valve Spring Tool
I have three different tools I've used over the last 6 years, and this is the best one I have for changing springs on an LS1:
http://ls1tech.com/forums/showthread.php?t=95463
I have replaced four spring sets with this tool (3 times on a Corvette, and one time on a Tahoe). Well worth the money....
St. Jude Donor '15
the VHP spring tool will do 2 springs at once. even duals. designed specifically for the LS1.
http://www.vincihighperformance.com/superwebdeals.HTML
Have you tried to rent one from your local auto parts store? I would hate to spend $100+ for something you use once every year or two.
The new one from Crane works great!
I got mine from Thunder Racing.
http://www.thunderracing.com/catalog...&vid=7&pcid=17
