Friend installed G5X3 - Need Help - Low power
Old 10-20-2004, 10:22 PM
slythetove
slythetove's Avatar
Default Friend installed G5X3 - Need Help - Low power
A friend installed the G5X3 cam in his 2002 Z06 this past weekend.
He went to Dallas to get tuned today, and just called me...
Only pulled 340 rwtq and 363 rwhp.
Obviously there is a problem. Trying to get some ideas while he drives back from Dallas.
He says the timing set allows for 8 degrees manual advance / retard during install. Does it sound like it accidentally was? I'm thinking this is the best possibility.
If not what are the other possibilities? Thanks.
Old 10-20-2004, 10:24 PM
Geneus
Geneus's Avatar
You sure he didn't re-install his Z06 cam by mistake? Very strange numbers, indeed.
Old 10-20-2004, 10:54 PM
slythetove
slythetove's Avatar
I sure hope not, because it was loping like crazy when he started it up. heh
Old 10-21-2004, 01:22 AM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Hi,
Who did the install, and who did the tune? What else does he have done to the car? It sounds like the cam is in wrong? What brand of timing gear did he use? (if he advanced it 8 degrees, he might have other problems now.
Have him call me tomorrow at LGM.
Lou G
972-272-7753
Old 10-21-2004, 01:25 PM
slythetove
slythetove's Avatar
Lou thanks for taking the time to reply here.
Home install. Tuning done somewhere in Dallas don't know.
I'm thinking by the numbers he's telling me that its' installed 8 degrees retarded.
I have passed these threads to him also, so hopefully he will call you if he still needs to.
You're a class act for sure to take the time to look at this.
Old 10-21-2004, 04:18 PM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
While leaving Dallas tell him to shoot over to Wylie and visit LG Motorsports
Old 10-21-2004, 04:35 PM
slythetove
slythetove's Avatar
He's in Austin now. He was driving back last night at like 9pm so I told him I'd get the ball rolling by posting the thread.
The latest update he's given me is that he's got no compression in number 8 right now.
He's apparently talked to Lou a little also at this point. Very cool Lou. Very cool.
Old 10-21-2004, 11:55 PM
slythetove
slythetove's Avatar
Ok, he pulled the valve covers and found a pushrod off a rocker. Here's his latest update, and a new problem:
"Okay I found a pushrod on cylinder 8 had come off the rocker arm. This must have happened on the initial startup as we heard a pop. The pushrod was wedged between the rocker and head so it wasn't even contacting the lifter which is why we didn't hear any strange noises. The valve was constantly closed! So I basically had my car tuned on 7 cylinders and made 363 rwhp.
Onto my new problem.
I went on a 1 mile test drive and the car ran terrible. I had to stop because I smelled smoke. As it turns out the cats were cherry red (LG Random 3"). I let it cool down and limped home but they were red again when I got back. Any ideas what my new problem is? I don't THINK it's clogged cats because they were fine before I fixed the bad cylinder. Any advice is appreciated."
Old 10-22-2004, 01:03 AM
slythetove
slythetove's Avatar
Got distracted apparently during reassembly. 4 passenger side wires left off.
Should be sorted now.
Old 10-22-2004, 11:42 AM
F1_SS
F1_SS's Avatar
If he left 4 wires off the tuner should have noticed that when the car was throwing misfire codes up the wazoo. I know they ls1/6's pick up knock from the cam but still.
Old 10-22-2004, 12:12 PM
90 droptop
90 droptop's Avatar
I think it was a joke............... are you for real or jok'n back?
Old 10-22-2004, 12:28 PM
Torched Z
Torched Z's Avatar
The car was dyno tuned with the rocker arm/pushrod problem (G5X3 112 on stock headed Z06). I'm not sure why the tuner didn't notice a misfire on #8. I got the car home, found the rocker arm problem and repaired it.
In the process of putting everything back together I got distracted and left 4 plug wires off the passenger coil packs. When I drove it I was dumping fuel from those cylinders into the cats and making them red hot. The plug wires are now on and the car runs like a champ.
Thanks to LG for calling me and working through my problem. For the record, LG did not do the tuning.
Old 10-22-2004, 01:12 PM
Watchful
Watchful's Avatar
Location: An Englishman drinking his way through Tewksbury MA
St. Jude Donor '09
It's not at all relevant to the thread, but the phrase "8 degrees retarded" made me laugh. Sounds like a good name for one of those ghastly boy bands!
Old 10-22-2004, 01:16 PM
gojo
gojo's Avatar
Not relevant? HMMM!
Old 10-22-2004, 04:38 PM
slythetove
slythetove's Avatar
That would be an awesome boy band name!! hahah
Old 10-22-2004, 04:39 PM
Z06ufgrad2002
Z06ufgrad2002's Avatar
Glad to hear you got it all sorted out.
Old 10-22-2004, 11:57 PM
dvandentop
dvandentop's Avatar
OMG forgot 4 plug wires LOL
To Friend installed G5X3 - Need Help - Low power
Quick Reply: Friend installed G5X3 - Need Help - Low power
