Are ARP studs worth the $100 more then bolts? more within
Old 10-20-2004, 11:33 AM
T_Vert
T_Vert's Avatar
Default Are ARP studs worth the $100 more then bolts? more within
I know studs have a more even clamping force but is cylinder head lifting really a problem on the ls1? Is it worth it to spend the extra $100 for this. Im trying to do this on a budget. i will have a very mild setup of ls6 heads and a stealth II cam.
Dave
Old 10-20-2004, 11:40 AM
Chris@East Coast Supercharging
Premium Supporting Vendor
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
absolutely
Old 10-20-2004, 11:47 AM
ICULUKN-C5
ICULUKN-C5's Avatar
Originally Posted by CHRIS NJ C5
absolutely
I would have to agree.... ARP studs are significantly stronger than bolts. You dont want your head bolts to be your week link. The LS1/6 head only has 4 bolts unlinke traditional small block chevy.
Old 10-20-2004, 11:56 AM
T_Vert
T_Vert's Avatar
Is head lifting a problem on the ls1 to the point these are necesarry? Im going to be running a 10.5:1 ish compression. I dont think ive heard of any problems w/ the bolts on this board, are they not up to the task??
Dave
Old 10-20-2004, 12:33 PM
Patches
Support Corvetteforum!
Patches's Avatar
Dave, check my response on this in this currently active thread.
http://forums.corvetteforum.com/showthread.php?t=929311
Old 10-20-2004, 02:17 PM
Jackal
Jackal's Avatar
Yes they are worth the extra money.
Old 10-20-2004, 02:39 PM
XPC5R
XPC5R's Avatar
Studs are great for re-useability and strength, but new stock GM bolts will hold all your setup can put out if $$ are tight. Put the money towards a good oil pump or UD pulley, especially the former.
Same argument for cometic gaskets.
Just my opinion... I used GM bolts.
Old 10-20-2004, 02:58 PM
frodo84
Uneducated overachiever
frodo84's Avatar
I just posted to the other thread also, you can get the ARP bolts for $133 versus $219 for the studs. I would think that either is a big step up from the GM bolts just for the ability to be reused, and I am also wondering about retorqing the heads after a couple of heat cycles. Any more input on this? I too would love to use the studs, but if I can use the ARP bolts for about $100 less, then I probably will.
Old 10-20-2004, 03:36 PM
Patches
Patches's Avatar
I went through several heat cycle torque rechecks on my heads and they stayed properly torqued after the initial install.
Old 10-20-2004, 03:48 PM
comp
comp's Avatar
to me it's like insurence and peace of mind
To Are ARP studs worth the $100 more then bolts? more within
Quick Reply: Are ARP studs worth the $100 more then bolts? more within
