Euro taillight question..
I am interested in the True Euro tail lights Red /Amber ..Red/clear.
I wanted to know if on the true euro versions do the amber and the clears blink when the turn signals are on..or does the red/amber only blink.
A forum vender sells all the three combinations Red/amber....Red/clear
and finally I assume True euro ..Red/amber..Red/clear.
I need to know if the true euro version blinks both?
thanks Chuck
thanks Chuck
The euros, whether clear or amber, blink just the clear or amber portion. The red portion is just for the brake light. This is assuming the proper wiring harness adapter is used which converts it to two single filament bulbs instead of one dual filament.
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
look in my sig the bottoms flash i figured since both blink i might as well put the red clear
1 Post
Cruise-In V Veteran
Location: No more yankee my wankee, the Donger is tired!
1 Post
In europe, they have a wider plate, which means you no longer have reverse (backup) lights. This is why there is a clear.
When turning, only the amber should flash.
Now vendors in the US have made the harness for turn signals only, since we still have the reverse lights at the sides of the plate. So you can either choose the white versions and use amber bulbs (or clear and look ricey) or use the amber lenses.
