Oil Change - Oil Life reset procedure - Help
Um, So I can't remember what the procedure is to reset the Oil Life on the DIC back to 100% - And I can't seem to find it when I search the forums...
Can somebody please tell me what the procedure is again.
Thanks in Advance!
Thanks in Advance!
There are 2 ways but this is the easier of the two:
Set your DIC to display Oil Life %
Press RESET button and hold for 5 seconds.
This will set it to 100% and you are done.
Received 1,673 Likes
Originally Posted by Ls1Rat
turn the key on and step on the gas 3 times while you are scrolled to the oil monitor
Would like to meet the engineer who invented this.
Frederik
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Worked great - Thanks
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Just did this.....it worked great, thanks
