Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2004, 10:07 AM   #1
stevieturbo
CF Senior Member
stevieturbo's Avatar
Default LS1 coil wiring
I tried a search, but couldnt find any info.
Im doing an install using an LS1, with an aftermarket ecu, but I need to know what the 4 wires are going to each coil ??
I can assume one is a +12v, one a -ve trigger, and one a chassis ground.
What is the 4th wire for ??
Ive had this reply on LS1 tech so far....
From Corvette fuel injection, the four wires are:
Ignition positive voltage - pink
Ignition Control Signal - light blue, purple, dark green, or red depending on which coil
Reference low - brown
Ground - black
can anyone identify what the brown/ reference low wire does or if it is neceassary.
My ecu only has the normal trigger setup for firing a coil, which is one trigger wire per coil.
Cheers, Stevie
stevieturbo is offline   Reply With Quote
Old 08-07-2004, 01:22 PM   #2
runamuk
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '04
runamuk's Avatar
I'll try to remember to look up the wiring diagram when I get home
__________________
This car was completely destroyed by Hurricane Katrina in 2005 and then rebuilt by me in 2007, see my rebuild pics at
http://s148.photobucket.com/albums/s10/rjgroth/
runamuk is offline   Reply With Quote
Old 08-08-2004, 07:59 AM   #3
runamuk
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '04
runamuk's Avatar
The wiring diagram shows the brown wire going into the PCM and like you said it's labeled "low reference" so I guess since your aftermarket ECM doesn't use the low reference just cap and stow the extra wire and see if it has any affect on the coil, I doubt it will.
Old 08-08-2004, 08:02 AM   #4
stevieturbo
CF Senior Member
Others have suggested its a reference ground...
I'll give both a try, and see what works
Thanks for the help...
Old 08-09-2004, 02:20 PM   #5
Heretic
CF Senior Member
Ground - black
Cheers, Stevie
The driver is built into the coil. The reference wire is a separate ground for the trigger signal (probably a 5 volt square wave like GM HEI stuff) to allow the PCM to diagnose a bad coil/driver.
If you don't have a distributor, or an electronic equivalent, you won't be able to use a aftermarket ECU setup on the LS1.
Heretic is offline   Reply With Quote
Old 08-09-2004, 03:12 PM   #6
stevieturbo
CF Senior Member
Can you elaborate ?
Why woud a distributor be of any use on a car with 8 coils ?
All coils I have came across before simply switch to ground to fire. ie when the trigger wire is grounded, the coil is on. When released, it fires via back emf. Are you saying these coils are totally different then ?
What about aftermarket high power coils then, that feature normal wiring methods, that would bolt onto the LS1 brackets ?
Reload this Page LS1 coil wiring
Tags
coil, diagram, ls1, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS1 Conversions HERE! holley505 C3 Tech/Performance 64 03-04-2005 09:56 PM
F.S. 03 LS1 complete motor NBM-Y2K-VERT C5 Parts for Sale/Wanted 12 02-01-2005 03:40 PM
Coil Conversion done Mr Mojo C4 Tech/Performance 126 10-02-2003 02:54 PM
F/S NEW LS1 Block, heads, crank, oil pan, intake, injectors, gstama C5 Parts for Sale/Wanted 11 05-05-2003 02:01 AM
WTB: Complete LS1 Vette engine pmg C5 Parts for Sale/Wanted 10 03-21-2003 03:31 PM
Check Engine light after LS1 edit. OK to disconnect battery to reset? Crushinator C5 Tech 10 08-03-2002 02:46 PM
Ok give it to me straight...LT4 vs. LS1 iroc22 C4 Tech/Performance 33 04-21-2002 02:19 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
