Thought... Will a CTS-V, GTO or upcoming C6 shifter work on a C5
I was just thinking... the CTS-V and upcoming C6 shifter is shorter and said smoother than the C5, right?
Just wondering then if those OEM shifters will work/retrofit on the C5.
If not the CTS-V then maybe the C6? The trannies should be similar.
Is it the shifter that is improved or internals in the tranny?
I actually have no issues with the stock shifter, but if the newer shifter can be retrofitted and is better than any current aftermarket shifter then that would be interesting.
Robert
WAs about to post the same thing!
The C6 is also a rear mount tranny, so it's shifter might be the same base.
Received 8,928 Likes
The C6 tranny is being modified to change the shift linkages to make the shifting better. The shifter itself is shorter and may or may not fit. The only way to get the C6 improvements is to go with the new tranny.
Bill
Bill
