Is a bigger throttle body going to help that much?
I'm fixing to be installing a H/C setup on my car. How vital is it to go ahead and do the TB along w/it. thanks--Andy
imo... it is not necessary for head /cam... really only need it for big bore/ strokers.....may actually hurt part throttle driveabilty....also cause idle issues......
When I was researching the same swap Vinci highperformance told me until a bigger intake came out it wouldn't help much, maybe 3or4 rwhp. I saw in one of the corvette magazines a test on the new FAST intake give www.vincihighperformance.com alook to see if they've dynoed the intake yet. Gary
Vinci installed the 90mm FAST setup on my stroker but a bitch to tune--Nick Williams is coming down this weekend and we are installing his latest version on the fast intake and it should run great--a bigger or ported TB on an ls6 intake is probably not worth the trouble--TPIS makes a widemouth oval 1200cfm TB and they alter the ls6 intake to accept it in the 900 range for both pieces and this has worked well--a lot of the heads cam guys have put the 90mm FAST setup and TB on their cars with great results and are getting 20 to 25 more rwhp out of their H/C setups and the 346 ci cars are easier to tune it in on by far---I would recommend using Nicks 90mm TB however it has become a far superior piece and the tuning is a breeze comparatively in fact most guys are installing it with the same tune they have for the smaller TB and there is very little tweaking at all but you would be very impressed with throttle response and the power--
Not that GM is the be-all, end-all when it comes to what works or doesn't work, but... from their press release about the LS2 motor --
A summary of new or changed components for the Gen IV architecture:
Larger 90-mm throttle body: The 6.0-liter displacement requires a higher volume of intake air; the Gen III throttle body is 75 mm. The new throttle body is mounted to a revised-design composite intake manifold with tuned runners to optimize airflow to individual cylinders.
I am going to experiment with a 90 mm setup soon on my car to see if it will get me any more hp. If it doesn't, I'll put the stocker back on and sell it.
You'll never know unilt you try it!!!!!
90 mm Fast intakes have been used by many, with stock displacement, and with the right TB have been very successful. Even with A4 cars.
I have no sound proof (of performance gains) of this - but my car has a 90mm FAST and 90 mm Nick William's TB and runs like a scalded dog.
Originally Posted by Bink
A ported stock throttle body with proper idle tuning helps al H&C cars. Proof - LPE puts one of their ported stock TBs on every application that goes out of their doors ( personal conversation- Ed Potter).
Where can I get Nick Williiams info ? Thanks Gary
