recommended oil filter for '02 Z06?
I know everyone has an opinion regarding tires and oil, so how about a favorite oil filter? I've used Fram products for all of my other vehicles and have been very satisfied. Also, how much do you pay for an oil change in your area of the country? Do you take your baby to the dealer or to any old service station? The dealer here in Alaska wants to charge $80 for an oil change.
Re: recommended oil filter for '02 Z06? (Nfuego01)
Buy the ST3506 from WalMart for $2, it is made by Champion Labs and is a much better filter.
Buy Mobil1 or Supertech Synthetic 5W-30 from Walmart and just pay the labor to have the work done at your local station. Make sure they pre-fill the oil filter with fresh oil before they screw it on.
Re: recommended oil filter for '02 Z06? (Sandra Bigwoode)
Fram is crap.
Fram is crap.
Spend $8.00 to $12.00 and buy a A/C Delco UPF44 filter for your $50,000.00+ Vette.
Bill
Re: recommended oil filter for '02 Z06? (Bill C)
Fram is crap.
Thats a good one. A filter for $2.00. The manufacture had to make money and Walmart will pull a profit out of this $2.00 sale. Sounds like a high quality product.
Bill
Fram is crap.
Bill
I like the Baldwin B31 as it shows a good combimation of flow and filtering.
Take a look at: http://www.oilfilterstudy.com/
Fram is crap.
Bill
Fram is crap.
Bill
http://theoildrop.server101.com/ubb/...?ubb=forum;f=6
The oil filters are all assembled by automatic lines, their content costs are likely similar, branding and fancy logos are what you are paying for...
Re: recommended oil filter for '02 Z06? (Richin Chicago)
The UPF series have very low flow rates and wouldn't my choice.
Isn't the oil pump a 3 lobe positive displacement pump, much like a roots type blower, but pumping oil instead of air?
Re: recommended oil filter for '02 Z06? (nuke61)
I'd like someone to explain how this is possible. I've worked with positive displacement pumps and centrifugal pumps that pump liquid, and with PD pump, the flow rate you get is the flow rate you get. IOW, you cannot adjust flow except by reducing the speed of the pump. If you close a discharge valve, you either break pipes or the pump.
"AlohaC5" Senior Member
I highly recommend the Baldwin B31 filter (same company the manufacturers the AMSoil filter). http://www.baldwinfilter.com/
Fram is crap.
Re: recommended oil filter for '02 Z06? (AlohaC5)
I think the K&N HP1007 is one of the best. I just bought two of them, even though I still haven't found a C5 yet! (but I should have one within the next week or two, and I'll be changing it's oil as soon as I get it home)
Fram is crap.
Bill
Actually the Supertech may be a better filter than the UPF 44 for a C5 particularly if you are going to run the car hard. The UPF series have very low flow rates and wouldn't my choice. The Supertech is made by Champion which also makes some of the Delco filters.
Fram is crap.
Bill
Running the Baldwin here also. Amsoil is another good filter.
Re: recommended oil filter for '02 Z06? (Patman)
I use a K&N oil filter also.
Re: recommended oil filter for '02 Z06? (Blkout)
Unless you know how the pump and system work, how can you then decide which filter is "best"?
Basic questions:
1) Where is the oil pressure sending unit relative to the filter? Is it downstream (after) the filter?
2) If the oil pump is a PD pump, then it will flow what it's rated at, regardless of what oil filter you use; however, since the real world results show that the oil pressure changes, that means it cannot be a PD pump
3) If its pump curve looks more like a centrifugal pump, regardless of its design:
A) IF the oil pressure is LOWER, then it is flowing MORE oil, assuming that the filter is the restriction in the motor
Take a look at the following "typical" centrifugal pump curve; flow is greatest when DP is lowest and vice-versa.
http://www.mcnallyinstitute.com/02-html/2-03.html
[Modified by nuke61, 3:17 PM 6/24/2004]
Basic questions:
Basic questions:
3) If its pump curve looks more like a centrifugal pump, regardless of its design, and:
A) IF the oil pressure is read AFTER the oil filter, that means a filter with a LOWER indicated oil pressure is flowing MORE oil
B) IF the oil pressure is read BEFORE the oil filter, that means a filter with a LOWER indicated oil pressure is flowing LESS oil
So, where is the oil pressure sender, before or after the filter?
Basic questions:
http://theoildrop.server101.com/ubb/...c;f=6;t=000513
Yeah, disregard original post
What I failed (miserably) to get across was:
With a centrifugal pump lower DP == greater flow
<bad info deleted>
[Modified by nuke61, 3:39 PM 6/24/2004]
<bad info deleted>
Naw, B was incorrect. Original post has been corrected.
I see people here upset that changing from filter X to filter Y dropped their oil pressure. Well, assuming nothing else changed in the system during the time you changed from X to Y, if the oil pressure dropped, that means you're getting more flow.
Ask youself, do you want pressure or flow?
Horrible brain fart...
Lower DP would mean greater pressure at discharge of filter. Sorry for all MY confusion, I hope I didn't add to any of yours
[Modified by nuke61, 3:34 PM 6/24/2004]
