Installed Vararam yesterday and have the same problem I have with all intakes
I can never get these two damn tabs that hold the air bridge in place to seat all the way down! :cuss Everything fits perfectly. Everything lined up perfectly, just like every other intake I've ever installed on my C5's. I had a twin flow on my '97, blackwing on my '02 Z06 and now the Vararam. And every time I get this... http://temp.corvetteforum.net/c4/nat96lt4//vram.jpg
Anyone else have this problem? :confused:
[Modified by Nat04Z06, 11:58 AM 5/5/2004]
Re: Installed Vararam yesterday and have the same problem I have with all intakes (Nat04Z06)
I wonder if it's a lack of flexibility (compared to the stock components) between the stuff before and after the MAF. Maybe you could loosen the straps on both sides of the MAF, and see if the air bridge will seat, then tighten. :confused: :cheers:
Re: Installed Vararam yesterday and have the same problem I have with all intakes (Dan_the_C5_Man)
I thought mine was the only one that wouldn't line up!! I have a carbon fiber bridge that we installed about two years ago and the tabs wouldn't line up. I was told it won't line up because it was pre-production bridge. :rolleyes:
I have noticed that the newer aftermarket bridges don't have the tabs.
[Modified by 1g1yy, 8:01 PM 5/5/2004]
Re: Installed Vararam yesterday and have the same problem I have with all intakes (1g1yy)
I suggest that you follow Dan the C5 man's advice. Good luck!
Which filter do you have in the airbox? Make sure the filter is in the box properly and make sure the airbox cover is fully seated.
If you still cannot get it to line up ask Patrick for a filter with a thinner foam surround. He makes them in different sizes.
The vararam isn't going anywhere, since it bolted in at the bumper. Mine didn't line up either, so I just removed the grommets & their mounting tabs. Looks alot cleaner & I don't worry about it anymore. Scott
Re: Installed Vararam yesterday and have the same problem I have with all intakes (99 The Hard Way)
mine is the same way. wont seat all the way down.
dave
dave
same problem with my blackwing, seems like its a hit or miss issue on the cars
Mark :seeya
Nat,
My VaraRam installed with the same gap. Don't worry. Just enjoy the added power above 60 MPH.
:seeya
:seeya
I left everything a little loose and then worked my way from throttle body down to mass sensor then removed all that and snugged up vararam then reinstalled that section . No problems here, you just need to remold it a little. I ditched the tabs i thought it looked better without them.
had the dealership put my Vara Ram in, no problems sorry you are having difficulty. Love the Vara Ram- no problems with seal.
Well, I feel a little better now knowing it's not just me. :) Thanks for the replies guys!
Nat, Here is what I try to do. Make shure the harnes from the massair is not in the way of the tabs. lift up the lower box as you slip the cupler on(do not tighten) and as you lower the bridge on to the tabs watch that the lower conection stays together( if you have to, use the but end of a screwdriver to seat the tabs down) now tighten the lower coupler, and rock the upper hose to the throtle body. It is easer with two people, but can be done by one easly the 2nd time around. Hope this helps. Ric
I can force mine in, but it will never stay. I just gave up.
Take the tabs and the rubber insulators out. They really don't do anything anyway.
