Help!! Where is the Blower Motor Relay (HVAC)
Old 01-19-2004, 10:50 AM
dave777
dave777's Avatar
St. Jude Contributor
Default Help!! Where is the Blower Motor Relay (HVAC)
I cannot find the Blower motor relay. My fuses are good so I am down to this. I have the service manuals but they do not show it. My blower is not working at all.
Old 01-19-2004, 11:09 AM
Patches
Support Corvetteforum!
Patches's Avatar
Default Re: Help!! Where is the Blower Motor Relay (dave777)
Dave, the blower motor resistor assembly is known to go bad. Quite common. It is located right next to the blower motor un der the passenger dash. I sent you the r&r procedure.
Old 06-24-2010, 04:19 PM
lazygearhead
1st Gear
lazygearhead's Avatar
can you send me the R&R proceedure? I think I have to do the same.
thanks - Mike
mgbruce@gmail.com
Old 06-12-2011, 07:20 PM
VETTHOG
VETTHOG's Avatar
Could I get one too? Thx
Old 06-12-2011, 09:29 PM
PEERPSI
PEERPSI's Avatar
What year and do you have the automatic climate control or manual control.
Old 06-12-2011, 09:39 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ABSOLUTELY!! We need to know what system you have before we can properly respond.. Duel Zone or Manual System? Year C5??
BC
Old 06-13-2011, 12:54 AM
VETTHOG
VETTHOG's Avatar
BC
Sorry, I should of included that info to begin with. It's a 99' with a manual system.
I actually have a different problem than the OP. For the last couple of years, speed 1 was the only setting that didn't work, but in the last week they all went out but speed 5. From what I've been reading, the problem is either the resistor or the relay, but can't figure out which.
Old 06-13-2011, 09:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is your issue!
The resistors on the board are most likely smoked like the ones in the picture:
Old 01-10-2012, 03:34 PM
KotasGM
3rd Gear
KotasGM's Avatar
Default same problem
I am having the same problem too and don't know where the relay is could you send me the r&r procedure too?
Thank You
George.kotas@navy.mil
Old 02-24-2012, 01:38 PM
fhernand
fhernand's Avatar
1999 manual a/c
fan speed 1 not working
thanks - Frank
fhernand@verizon.net
Old 02-24-2012, 02:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHAT PROCEDURE?? Just replace the module on the bottom side of the air box. You can purchase the module from www.gmpartshouse.com Call Gene Culley If you have the duel climate HVAC the module looks the same but is MUCH different inside and is MUCH more expensive.
Someone told me that Autozone may also have it but, I have never checked that out.
Old 02-24-2012, 02:34 PM
KotasGM
3rd Gear
KotasGM's Avatar
Default My blower motor is stuck always On.
I have a similar problem, which I think must be the relay, my blower motor is always ON. It won't go off even when the car is off and the keys have been removed. WTF Over? If this isn't the relay what could cause it to be always on? I got a new relay from AutoZone, but can't find where it is, I think it is on the Firewall behind the Glove Box?
Old 02-24-2012, 08:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF YOU have duel climate control,,,,, WHAT RELAY???? There isn't one...
If you have manual HVAC controls,,, there IS a relay BUT,,,,,, it will NOT cause the FAN MOTOR to stay ON:
The relay that your looking for is INSIDE the module that is mounted on the BOTTOM of the air box..
You can dissect that module and you will find that relay in side.. Hey,, maybe you can solder a new one in and save a few bucks. Give it a try!! MAKE SURE THAT YOU DOCUMENT IT!!!!!!! Lots of PICTURES!!!
As you can see, I was able to get my hands on the duel climate module and take it apart. That one failed due to a burned circuit trace.
BC
dogboy (03-20-2024)
Old 03-30-2012, 07:58 PM
BradsDCM
BradsDCM's Avatar
My HVAC is working intermittently. Both heat/AC. I can turn it on, no lights come on or anything. If I leave it on, it will come on and off when it wants to. Could this be linked to the module also? Thanks Bill!
Old 05-09-2016, 10:35 PM
rtholder
2nd Gear
rtholder's Avatar
1997 C5 with dual climate:
After reading all the great posts I ordered new module (opened up to be sure it was the same as pictures). Going to try to replace next week, and wanted to see if you send me the R&R proceedure?
Old 05-10-2016, 01:03 PM
bsmutz
bsmutz's Avatar
2000 with dual climate control. When I first got the car, the fan made a lot of noise when turned up. Didn't sound good. Then I found out the air wasn't working, so had it recharged. Fan was working, but not noisy anymore and not as strong as my '98 was, so I took the battery out and found there was a mouse nest behind the battery and in the intake for the fresh air. Sucked out all the stuff I could see with the vacuum and ran a small hose down into the ducting as much as I could. Now the fan doesn't work at all. I'm thinking it is either jammed up with crap or bit the big one. What's the easiest way to get to the motor? Is there another thread on here that goes into the procedure for getting it out? Thanks! Never mind, I figured it out.
Old 05-10-2016, 02:38 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You just need to remove the close out panel and STUFF your head under the passengers side of the dash and look UP. THREE SCREWS, One connection and a rubber air hose and its OUT..
If you had nest material in the air intake opening , you most likely have crap inside the AIR BOX THAT WILL NEED to be extracted... Been there done that!..
Hmmmmmmmm:
The following 3 users liked this post by Bill Curlee:
bsmutz (05-10-2016), dogboy (03-20-2024), wheelswheeler (08-14-2016)
To Help!! Where is the Blower Motor Relay (HVAC)
Old 05-10-2016, 02:44 PM
rtholder
2nd Gear
rtholder's Avatar
Any chance anyone still have a copy of the R&R procedure mentioned here for the blower motor control processor they could send me? Thanks for any help!
Richard
rtholder@c5corvette.com
Old 05-11-2016, 12:34 PM
bsmutz
bsmutz's Avatar
Whipped the old one out (well, more like cursed the old one out). Stupid connector behind the motor with it's impossibly short wires gave me fits until I accidentally pushed the right place and the motor fell into my hand. Not much debris back there, must have gotten the vast majority with the vacuum from the other side. Tested the motor when I got it out and no spin. Went and picked up a new one for $60. Took a few tries to get it lined up with the holes correctly. Looks like the mounting holes are symmetrical, but they're not. Now I have a fan again! Thanks to all who've posted about this.
Old 06-14-2016, 10:26 AM
Skiier46
1st Gear
Skiier46's Avatar
Default Blower motor relay
Is it necessary to replace the complete relay/fin set up ?
Quick Reply: Help!! Where is the Blower Motor Relay (HVAC)
