Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-26-2003, 11:03 PM   #1
vettewreck
CF Senior Member
vettewreck's Avatar
Default what is the best throttle body?
who makes the best throttle body for a C5? Is it better to send my stock one out to be ported and polished or just buy a 80mm one new? Who should I send it to if you guys steer me in that direction?
vettewreck is online now   Reply With Quote
Old 11-27-2003, 01:00 AM   #2
rfgoss1
CF Senior Member
rfgoss1's Avatar
Default Re: what is the best throttle body? (vettewreck)
Unless you are running a power adder, like a turbo or SC, or a stroker, then just get a Shaner ported TB. You can send in your core and the price is right. It is a sweet piece.
Cheers
Randy
rfgoss1 is offline   Reply With Quote
Old 11-27-2003, 01:06 AM   #3
Shortimer
CF Senior Member
Support Corvetteforum!
Shortimer's Avatar
Default Re: what is the best throttle body? (rfgoss1)
:iagree: I've read some reports of guys/gals dyno testing their rides with these bigger throttle bodies and finding little or NO gain. They aren't cheap either. :chevy
Shortimer is offline   Reply With Quote
Old 11-27-2003, 01:15 AM   #4
LittleBoyBlu99
CF Senior Member
LittleBoyBlu99's Avatar
Cheers
Randy
:iagree: :iagree: :cheers: :cheers:
LittleBoyBlu99 is offline   Reply With Quote
Old 11-27-2003, 01:17 AM   #5
NVR BRNG
CF Senior Member
Send a message via AIM to NVR BRNG
Shaner or Bauer are 2 guys that do good work. I had mine ported by Bauer, the primary reason I decided on Bauer is because (at the time) he offered powerder coating too. The port & polish work was done well and the area around the breather connector was epoxied & drilled out to smooth out the intake side of the TB better. On my bolt-on motor, probably not much improvement in the RWHP department, but I did notice improved throttle response, especially once the motor got up on the cam and the hammer is put down. Consider this mod as part of your overall package, and not a significant RWHP improvement all by itself.
NVR BRNG is offline   Reply With Quote
Old 11-27-2003, 09:16 AM   #6
OldSStroker
CF Senior Member
I test C5 ported TBs for Bauer Racing. My basically stock '97 A4 still idles at 550 with the TB ported especially for an automatic. His M6 porting is slightly different, as they don't seem as sensitive at idle. Currently mine is coated bright red to match the lettering on the fuel rail covers. I like the semi-gloss black however.
OldSStroker is offline   Reply With Quote
Old 11-27-2003, 10:29 PM   #7
BLU-JACKET
CF Member
Vararam makes a new insert for the TB that's called the Velocity Stack. Apparently it creates the same effect as a ported TB. I noticed it on Nates-Corvette Garage site for $30.00... :cheers:
BLU-JACKET is offline   Reply With Quote
Old 11-27-2003, 11:11 PM   #8
vettewreck
CF Senior Member
vettewreck's Avatar
Default Re: what is the best throttle body? (BLU-JACKET)
guys thank you first of all but I am running a magnacharger and a vararam. Soooo...... should I send mine off to this shaner thing or what?
[Modified by vettewreck, 4:12 AM 11/28/2003]
Old 11-28-2003, 04:57 AM   #9
EFI-1
CF Senior Member
EFI-1's Avatar
Back when I was looking for a ported TB for my SS, I did some reasearch and found Bauer to be one of the most reputable.....after placing my order with him and receiving the part within a week I knew i had made the right decision. Excellent service, fast, and an awesome product. Bret does some wicked work on TB's.
EFI-1 is offline   Reply With Quote
Old 11-28-2003, 06:47 AM   #10
V8_Club
CF Senior Member
V8_Club's Avatar
Send a message via MSN to V8_Club
Default Re: what is the best throttle body? (EFI-1)
BBK 80mm. Slight HP increase if stock will come into play with new LSX manifold ( larger TB intake ) .
V8_Club is offline   Reply With Quote
Old 11-28-2003, 08:49 AM   #11
vetterdstr
CF Senior Member
CA Events Coordinator
vetterdstr's Avatar
Stock TB's work great, I had mine ported years ago and still run it now. If there was anything better than the stock part, it would have been installed long ago. :smash:
VR :cheers:
vetterdstr is offline   Reply With Quote
Reload this Page what is the best throttle body?
Tags
97, automatic, body, c5, corvette, corvetteforum, forum, put, throttle, trotel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
