Rear wheel bearing/hub assy-1998
Old 11-24-2003, 05:20 PM
84bronzevette
84bronzevette's Avatar
Default Rear wheel bearing/hub assy-1998
Has anyone replaced the rear hub/bearing assembly and where did you purchase them? The dealer wants $486 wholesale price for them. Autozone lists them for $129 but they don't stock them. I can't believe that they are the correct assy if they are selling that cheap. Any input appreciated,
thanks; Scott
Old 11-24-2003, 05:41 PM
Jim 47
Jim 47's Avatar
Default Re: Rear wheel bearing/hub assy-1998 (84bronzevette)
Scott: Rockauto has the rear hub assembly listed for $164.79. They also carry the GM hub assembly (with integral sensor) for $517.41.
Yes these are the same assembly most likely made by different manufactures and one has the sensor in it and the other does not.
It's a tough decission isn't it?? :crazy:
Jim
Old 11-24-2003, 06:40 PM
Mark 84ltblu
Mark 84ltblu's Avatar
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Check Advance Auto & NAPA. They both used to carry the Timken hub assembly for under $ 200.
Old 11-24-2003, 07:01 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Default Re: Rear wheel bearing/hub assy-1998 (Jim 47)
What happens with no sensors :eek:
Old 11-24-2003, 07:17 PM
Gene@FredBeans
Gene@FredBeans's Avatar
Hello... give me a call and I will hook you up with a great price!!
Gene
Old 11-25-2003, 03:42 PM
84bronzevette
Default Re: Rear wheel bearing/hub assy-1998 (Gene@FredBeans)
Jim, Gene and Mark- thanks to you all. Gene I'll be calling.
Scott
Old 11-25-2003, 05:33 PM
vette.se
vette.se's Avatar
It is GM # 7470571 and are sold by gmpartsdirect.com at $348. You will need a 34mm socket to remove the assembly.
:cheers:
Old 11-25-2003, 07:05 PM
thatchh
Cruising
thatchh's Avatar
Just call your local bearing dealer and give them the Timken part #. (available in the installation guide in the archives). I got mine from Kaman Bearings for about $150 per corner.
Thatch
Old 11-25-2003, 07:14 PM
MikeP
MikeP's Avatar
Scott what type of noice is your car amking? My 98 Vette when I turn hard left I hear what sounds like a my tire rubbing the wheel well like sound. I checked and found no sign's of any tire rub anywhere. Is this the type of nioce assiciated with a wheel bearing going bad? Is it when I turn and load the bearing up with the cars weight the reason I only hear the noice? I'm trying to trouble shoot before I drop the scratch for the bearing assembly. I found a post from a guy on the forum who did the changeout and provided a step by step with pic's for guys like me who will aleast give a stab at doing it myself befor I let the dealership bend me over.
If you want the web sight let know and I'll send it to you. Save the wave
Mike P 98 Coupe :flag :cheers:
Old 11-25-2003, 07:36 PM
69's Avatar
Default Re: Rear wheel bearing/hub assy-1998 (MikeP)
HeY Mike can you please post the wheel bearing link?
Thanks,
Kevin
Old 11-25-2003, 08:23 PM
jrda
jrda's Avatar
You can get the same exact TIMKEN bearings (hub assemblies) from AutoZone. The fronts are part number 513139 and are about $160 each. The rears are part number 512153 and cost about $130 each. These parts are exact replacements for the OEM parts. I could not see any difference between these and the originals.
[Modified by jrda, 7:24 PM 11/25/2003]
Old 11-25-2003, 08:41 PM
84bronzevette
Mike;
The car sounds like theres a beehive in the right rear and it gets progressively louder from 30mph as you speed up. Loading and unloading the bearing on turns affects the tone.
Scott
Old 11-25-2003, 08:52 PM
84bronzevette
Default Re: Rear wheel bearing/hub assy-1998 (jrda)
jrda;
thanks for the detailed r&r and part numbers! My buddy is going to be really happy as I had informed him that the dealer cost for the bearing was $486 and I couldn't believe the Autozone quoted price could be the right item! That is less than I paid for the rear bearings on my C4's and they have no sensor mounted in them! Now if only I can get the dealer to warranty the clutch release bearing I installed last March.
Thanks again to all; Scott
Old 11-25-2003, 08:56 PM
John Shiels
Someone said there is no sensor in them?
Old 11-26-2003, 08:38 AM
Mark 84ltblu
Curise-In V Veteran
Default Re: Rear wheel bearing/hub assy-1998 (John Shiels)
The bearing I got from Advance Auto had the sensor attached and was made by BCA. Retail was $ 168.00.
To Rear wheel bearing/hub assy-1998
Quick Reply: Rear wheel bearing/hub assy-1998
