Car is dying when slowing down
Old 11-23-2003, 07:26 PM
Fish Elvis
Fish Elvis's Avatar
Default Car is dying when slowing down
My car dies when I'm slowing down after spirited acceleration. It only happens when I engage clutch or put in neutral and let the car slow. If I down shift and keeps the rpms up it seems fine. Does anyone have any ideas?
:confused:
Old 11-23-2003, 07:30 PM
pdd000
pdd000's Avatar
Default Re: Car is dying when slowing down (Fish Elvis)
:lurk:
Old 11-23-2003, 07:31 PM
Bob50th
Bob50th's Avatar
Is there any black smoke during this time? :flag
Old 11-23-2003, 08:18 PM
Fish Elvis
Fish Elvis's Avatar
Default Re: Car is dying when slowing down (Bob50th)
None
Old 11-23-2003, 08:42 PM
rhoeven
rhoeven's Avatar
Are you using an aftermarket airfilter which was over oiled?
Most likely, the heated MAF wire has to be cleaned.
Hope this helps
Roger :cheers:
Old 11-24-2003, 10:01 AM
pmarone
pmarone's Avatar
Default Re: Car is dying when slowing down (pdd000)
You also might want to check your entire intake system (from filter to throttle body) to ensure it's seated/sealed properly. Hard deceleration might cause the parts to shift enough to open a bad seat/seal, causing a vacuum pressure loss. I had this happen at the front end of the stock accordian air bridge.
Pete
Old 11-24-2003, 10:57 AM
R6_C5_CLS55
R6_C5_CLS55's Avatar
My car did that once and it turned out that I had a vacuum leak. I found one of the intake tube connections had come loose and once reconnected and tightened, it was good to go.
Old 11-24-2003, 05:14 PM
Fish Elvis
Fish Elvis's Avatar
Thanks for the suggestions, I do have an aftermarket filter, the oily one that came with the vararam.
Chris
Old 11-25-2003, 05:14 PM
Fish Elvis
Fish Elvis's Avatar
Any other things to look for while I'm under there???
:confused: :confused: :confused:
[Modified by Fish Elvis, 5:14 PM 11/25/2003]
Old 11-25-2003, 09:31 PM
Mikie C
Mikie C's Avatar
This also can be a symptom of a dirty throttle body. Remove it from the manifold, squirt some carb cleaner on a rag and clean the throttle blades on both sides and also the barrels. This is a maintenance item that is often overlooked. HTH
Mike :flag
Old 11-26-2003, 12:22 AM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Car is dying when slowing down (Mikie C)
Do you have any storred codes. Mine did the same thing and I had a air leak in the coupler between the MAF and throttle body. I had two DIC codes. MAF low air flow and MAF high air flow , at the same time! :crazy:
Old 11-26-2003, 03:34 AM
Superj
Superj's Avatar
I had the same problem as well but was able to address it. I found two things that could cause this issue. If your intake is loose and you are taking unmetered air in after the MAF due to a leak it can cause the car to stall at idle. In my case I was tripping a few codes that indicated the O2 sensors were bad. I replaced these and the car no longer stumbles or dies at idle. It would be especially bad after spirited run up. Good luck
Old 11-26-2003, 08:51 AM
Guest
Guest
Posts: n/a
Default Re: Car is dying when slowing down (Superj)
maybe there is a problem with the IAK motor and it needs to be adjusted.
Matt
To Car is dying when slowing down
Quick Reply: Car is dying when slowing down
