Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2003, 01:30 PM   #1
Andymi
CF Senior Member
Andymi's Avatar
Send a message via AIM to Andymi
Default Trouble code under 28-TCS C1233 H C (Right Front Wheel Speed Circuit)
I have a code which is turning my traction control and abs lights on.
I looked up the code and it says if is a right front wheel speed circuit open or shorted.
What is this, and how can I fix it?
Thanks for any advice.
Andymi is offline   Reply With Quote
Old 10-16-2003, 04:15 PM   #2
vetteshop
Supporting Vendor
St. Jude Donor '13
vetteshop's Avatar
Default Re: Trouble code under 28-TCS C1233 H C (Andymi)
Replace the wheel speed sensor jumper harness (lead that goes to the sensor mounted to the lower control arm)...Common problem :yesnod:
vetteshop is offline   Reply With Quote
Old 10-16-2003, 07:51 PM   #3
WCR_Timmy
Junior Member
Default Re: Trouble code under 28-TCS C1233 H C (C-5 TECH)
I'm getting a similar code, C1235 and/or C1238 (the right-rear wheel speed sensor). C5Tech, could you elaborate on what has to be replaced? Is it just the harness from the weatherpack connector on back to inside the wheel well? It's just an intermittent problem, but I'd like to know what I have to do to get it fixed. Thanks!
WCR_Timmy is offline   Reply With Quote
Old 10-17-2003, 02:47 PM   #4
vetteshop
Supporting Vendor
St. Jude Donor '13
vetteshop's Avatar
Default Re: Trouble code under 28-TCS C1233 H C (WCR_Timmy)
The 2ft section of jumper harness that connects to the front wheel speed sensor mounts to the lower control arm.Due to suspension travel,over time this harness will get an intermittent open or high resistance in the wiring.The harness was redesigned and left and right jumper harnesses are the same part# 10332527 and easy to replace,about $35.00 each.
Given that,a simple diagnoses would be to swap the jumper harnesses left to right to see if the fault moves to the other side ;) Wheel speed sensores are commonly misdiagnosed when the fault is simply the jumper harness that goes to the speed sensor :yesnod:
Old 10-20-2003, 05:00 PM   #5
Andymi
CF Senior Member
Andymi's Avatar
Thanks for the reply.
I checked this weekend, and someone unplugged the connector when I had some A/C Compressor work done.
Sprayed some electric clean, and works perfectly again.
Thanks.
Old 10-20-2003, 06:16 PM   #6
hardtop
CF Senior Member
hardtop's Avatar
I too had this Problem. I fixed it about three weeks ago by Changeing the Battery and spraying the contacts To the hub transmiter of the effected wheel with a "tech" spray. Before the fix, I would get "Service TC ABS and Active Handeling" every time I hit a bump, But no more :hurray:
[Modified by hardtop, 6:17 PM 10/20/2003]
hardtop is offline   Reply With Quote
Reload this Page Trouble code under 28-TCS C1233 H C (Right Front Wheel Speed Circuit)
Tags
1233, 2001, c1233, c1238, chevrolet, code, codes, corvette, dtc, fault, front, obdii, sensor, speed, tcs, trouble, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
