Change the M6 and diff. oil w/65k?
well, like the topic says, i was just wondering if there are any contraindications to changing the M6 trans and rear end oil w/ 65k miles on it. I'm not sure if it has ever been changed before? i bought the car with bout 50k. I was also wanting to put some new clutch fluid in, the shifting is starting to get a little sticky and i hope this will help, as well as be good maintanence.
Thanks for the advice, you guys are great!
Resident moron
Re: Change the M6 and diff. oil w/65k? (stngh8r)
Definitely change it, you can't hurt anything. Well, unless you forget to refill it. 2 quarts of redline (choose your weight) and some GM limited slip additive and you're good to go.
Dope
Dope
Re: Change the M6 and diff. oil w/65k? (Dope)
Dope
Dope
Redline's description "75W90 GEAR OIL
Recommended for most street driven and racing differentials. Excellent performance in conventional and limited-slip units. Also for limited-slip manual transaxles which require a 90 WT oil. Contains limited-slip friction modifiers.
Also the transmission takes just under 4 quarts of D4 ATF Redline.
Definitely worth the effort if you don't know the car's history.
Re: Change the M6 and diff. oil w/65k? (carpe dm)
Thanks for all the replies. Guess i will get on the job right now. What about the clutch fluid, havent seen any comments on that yet? Will it improve the shift quality, which is poor and sticky right now.?
Again, thanks for the info and link.
Resident moron
Re: Change the M6 and diff. oil w/65k? (Richin Chicago)
Dope
I'd b a little careful about adding any limited additive as the Redline fluid already has about 4% friction modifiers added to their 75w/90. Too much and you will just have an open differential.
Dope
People who claim that you don't need the additive have obviously never done a fluid swap and had to live with the car later. Try using just redline fluid and then do some tight parking lot manuevers.
Dope
Dope
Redline already has 4% friction modifier in and I sure wouldn't add anymore until I heard noise. As stated before too much friction modifier and you defeat the limited slip. If you want I'll E_mail Redline and ask their opinion, but I'll bet there is a whole lot of people that have put Redline in with no extra additives and not had a problem.
This might make a good survey!
I would give Redline a try. I know a guy who works in the industry and is a tribologist. Redline makes the most cutting edge lubricants on the market. They are very professional. Amsoil products are generally good, but they have some that are very over rated, such as there S2k oil. I'd go with RL and see how it works. Amsoil is the only company not using MoTDc, the molybdenum that is soluable. Every lubricant maker in the industry useses it and now Honda specifically calls for it. It's a great EP additive. RL motor oil uses it as well. No Hype with there products, just pure performance. Good luck. I questioned Amsoil about Moly and there response was mind-blowing. They said they don't use solids in lubricants. They must be a bit behind the times as the soluable Moly has been in oils for over 5yrs now and has gained tremendous poplularity. It's not the panacea, but it helps. Note, I'm not sure if RL diff. oil uses this....might want to check with them.
[Modified by bnpb, 11:22 PM 10/9/2003]
Resident moron
Thought I might also add, I'm 90% sure GM specifies the additive usage regardless of the fluid you use.
Dope
Dope
Re: Change the M6 and diff. oil w/65k? (Bandit1)
Definately change it! Try AMSOIL. I think you'll like it. :thumbs:
[Modified by IMQUIK, 11:33 PM 10/9/2003]
I'm going with AMSOIL. No additive required. After seeing a diff/tranny fluid change I know how easy it is.
Tom
Tom
Dope
I have a 2000 hardtop with 35000 miles which I switched to Redline at less than 1000 miles. It is fine and will make any parking lot manuever you want. Also had a Camaro SS with almost 50,000 miles on it with the same story.
From the link above here is the info I gathered from redline:
Redline says:
LIMITED-SLIP COMPATIBILITY Red Line Gear Oils, with the exception of the 75W90NS, already contain friction modifier required for operation in limited-slip differentials. Additional additive is not required.
I have emailed Redline and asked them if it would not hurt to add the GM additive to Redline.
Here is the reply from redline
The 75W90 would be suitable for the limited slip in your Z06 it contains 5% friction modifier, typically what is needed to reduce the chatter from the limited slip when making a slow tight turn. Adding more friction modifier if it isn't needed reduces the lock up of the limited slip and reduces it's effectiveness, so I wouldn't add it unless it is needed due to chatter and then only just what is needed. The friction modifier isn't a lubricant but just an additive to make the fluid slipperier for chatter control. The 75W90 should be suitable right out of the bottle without the need for the additive. Thank you for your interest in Red Line Oil.
Amsoil says it both ways on their website:
AMSOIL gear oils are formulated with friction modifiers for limited slip differential applications. There is no need to add limited slip or additional additives.
AMSOIL Series 2000 Synthetic Gear Lube provides limited slip performance. Although generally not necessary, original equipment manufacturers' limited slip additives may be used in conjunction with AMSOIL Series 2000 Synthetic Gear Lube.
[Modified by gmblack3, 12:25 PM 10/10/2003]
Re: Change the M6 and diff. oil w/65k? (gmblack3)
Unless you plan to do racing, save your $ and use MOBIL 1 products in both the tranny and rear end. AND ad the G.M. rear end additive. This is factory fill stuff. That's my 2 CTS. :cheers: :chevy :flag
Re: Change the M6 and diff. oil w/65k? (TheBigGuy)
I changed mine at 1002 on my 2004 Z06 shifting is better but just had it flat beded to dealer was locked in reverse gear. Took it off the flat bed and it was working ok. Hope I am close to home when it happens again :cheers: I did the magnitic kit from the C5 purchase/group /mall
1 Post
Re: Change the M6 and diff. oil w/65k? (Argo-7)
I have Redline in the rear diff. I did NOT add the GM modifier fluid. I don't have any chatter. Redline says its not necessary to add any modifiers.
mike
mike
Re: Change the M6 and diff. oil w/65k? (C5~Missle)
thanks for the many replies. I have the fluids now, just waiting for time to do it all. Did someone mention that it is pretty easy? Or is this something i should let a professional do?
