Need Shifter Wife can Shift - Detests Breathless
I just bought an 02 Z
Previouslty, I hated the stock shifter in my 01 Coupe and replaced it with a Ripper.
This time, I tried a Breathless.
The wife "DETESTS!!!" the BPP :cry
What shifter offers precision and a low shift effort?? I have already purchased a shortened stocker for the moment. Any other suggestions????
[Modified by Closer_2001, 3:52 PM 9/27/2003]
[Modified by Closer_2001, 9:37 AM 9/30/2003]
Re: Need Shifter Wife can Shift - Detests Breathless (Closer_2001)
Did you try weaker springs in the BPP shifter?
I don't know of anything lighter on effort than the stock shifter.
I'm using the Kirban unit and am very happy with it. Precise shifting with virtually the same effort as the stock unit. Have never missed a 2nd to 3rd with this baby, which is more than I can say for the stocker.
Cruise-In IV Veteran
St. Jude Donor '06-'07-'09
I have the Hurst shifter and I love it!! Yes, it is a bit stiffer than the stock shifter, but it is also adjustable.
Works great for me in my '02 Z06 :yesnod:
Re: Need Shifter Wife can Shift - Detests Breathless (runamuk)
It sounds like you'll just have more driving time available :D
Resident moron
The BPP has different springs available. Put in the softest ones.
Raise up the shift ****, or get a tall shift **** (more leverage, less effort).
If it's still not good enough, ban her from the car. The BPP is an awesome shifter.
Dope
Dope
Forget about the springs in the BPP, Ripper and such....Removing them all together is still too stiff as the centering springs in the tranny linkage is where most of the stiffness is.
The BEST compromise is a REAL shortened stocker.. Not the one where they take an inch off the top..
My Ripper was great when I 1st installed it... But it got old being in an Arm wresting match every time I wanted reverse...
So I custom shortened my stocker and LOVE it.. I am sure your wife will too.
Check this link...
Mine is the Chuckster mod...
http://benelliwang.badassride.com/Shifter/index.html
Check this link...
Re: Need Shifter Wife can Shift - Detests Breathless (DngrZne)
Replace the wife with one more compatible with the shifter :lol:
Eric,
Kirban here. Precise, but fairly low effort. My wife's not thrilled with it, but she doesn't drive the car often enough to matter.
Try replacing the tranny flluid with a good synthetic ATF, I put in Royal Purple in mine and it really smoothed out the shifting.
Re: Need Shifter Wife can Shift - Detests Breathless (chuckster)
Check this link...
Check this link...
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Would recommend the Hurst with the light springs installed. Its somewhat adjustable.
The Kirban is the easiest to shift, but is noisier than the others.
Nate
Nate
I replacrd the stock shift **** with a hardbar (www.hardbar.net), and the oil in the tranny to Red Line. My wife, who does not notice changes to the car noticed this one and LOVES it. The stock **** is too big, and feels like it is made of form rubber. The Hardbar is taller than stock so you have more leverage for easer shifts. The shifting is much more postive.
1 Post
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
My wife won't drive it...too bad you don't have that problem. ;)
Re: Need Shifter Wife can Shift - Detests Breathless (lager99)
Part of the reason she is driving the Z06 is that we sold her gas guzzling Tahoe in favor of a more efficient and less costly daily driver: 1994 Integra GSR 4 Door. She likes rolling in the deep ride on the weekends, etc.
The Chuckster mod looks very promising.
The Kirban will be tested shortly.
[Modified by Closer_2001, 12:15 PM 9/28/2003]
I emailed her the thread to elimate incriminating evidence later-on. Thanks!!!
[Modified by Closer_2001, 11:18 PM 9/28/2003]
If you want to get rid of the BPP I want to be first in line. Sorry about the situation with the wife.
James
James
