C5 performance tips
Old 09-25-2003, 11:01 PM
WideopenC5
WideopenC5's Avatar
Default C5 performance tips
I have just bought my first C5. I had a 1995 C4 that I did quite a few modifications to. This was a 300 hp car that seems like was a lot faster than my C5. I did the exhaust and MAF first. Then I did the air filter. A complete MSD ignition and 1.7 Crane gold series rollers. The 1st and only time I took the car to the track it ran 12.92 @ 121 mph. It was a 6 speed as well is my new one but i know it will not run 12's. I was hoping that someone could get me off on the right foot. I dont want to get into the block at all. I would rather spend a ton on a supercharger before I did that.
Old 09-25-2003, 11:17 PM
Scubanme
Scubanme's Avatar
Default Re: C5 performance tips (WideopenC5)
I previously owned a 90 C-4, totally stock. It indeed was faster than my C-5
was stock, but only to a certain point. If I was just cruising at a low RPM in 4th or 5th and wanted to accelerate, the C-4 was faster up to about 4,000 RPM, but once past that point the C-4 flattened out. The C-5 pulls much harder at a higher RPM and would totally smoke the C-4 as long as you keep the revs up. The C-4 had better torque down low and the C-5 has much better high RPM HPs. I think the twin throttle body and shorter intake runners
of the C-4 had more airflow velocity and made better torque. The larger throttle body and long intake runners fo the C-5 have more flow, but less
air velocity, which is better for higher RPMs...I could be wrong and maybe some of the engine builders can chime in on this?
:flag
Old 09-25-2003, 11:29 PM
WideopenC5
WideopenC5's Avatar
Default Re: C5 performance tips (Scubanme)
The C4 I had, had a few miles on it so I really wasnt worried about hurting it. But this one kinda scares me. I spent a long time searching for a black 6 speed with low miles. I trailored this car 13 hrs. So it is like my pride and joy. It just doesnt have that snap like I thought it would. I need to know where to begin with the mods and what would be the least harmful to my wallet.
Old 09-25-2003, 11:35 PM
Monster231
Monster231's Avatar
get a blackwing or some sort of intake first, then an exhaust. Headers are awesome on these cars. Next go with a LS6 intake and get a bigger MAF sensor and get LS1 tune.
Old 09-26-2003, 06:59 AM
Patches
Support Corvetteforum!
Patches's Avatar
If you want that immediate, snap-your-head-back kind of mod, try swapping out the rear gears to a 3.90 or 4.10.
Old 09-26-2003, 07:00 AM
lowdowndirty
lowdowndirty's Avatar
Default Re: C5 performance tips (Monster231)
:iagree: And in pretty much the same order. Conduct some searches on the intakes and exhaust as these have been debated a million times here. Then pick the ones YOU like the best.Once you have the basics (intake and exhaust componants) get the car dyno tuned w/ ls1edit at a REPUTABLE shop. The tune should make a big difference.
Good luck and congratulations.
Chris
Old 09-26-2003, 09:09 AM
Mr. Jones
Mr. Jones's Avatar
Default Re: C5 performance tips (lowdowndirty)
:iagree: mostly gears first, intake upgrade, exhaust, LS1 edit
I didn't do the gears first but I will fix that real soon
Old 09-26-2003, 09:20 AM
chuckster
chuckster's Avatar
They should sell the Vararam/4.10 combo as the DEFACTO Kick in the butt mod.
The Vararam Intake coupled with a 4.10 rear will make you think you have a 2003 Z06!
Old 09-26-2003, 09:25 AM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
If your trap speed is 121 and you only posted a 12.9 then your spinning the tires hard off the line, I'm willing to bet your 60' time is probably well over 2 seconds, get this 60' time down and you'll be high 11's :cheers:
To C5 performance tips
Quick Reply: C5 performance tips
