Denton 1/8th mile times and a few performance thoughts!
Old 09-14-2003, 02:31 AM
cscollis
cscollis's Avatar
Default Denton 1/8th mile times and a few performance thoughts!
I just got back from denton and I am getting better: Previously I ran 7.99 to 8.07 on 10 passes. Well tonight after a reprogram, 7.93 to 7.97 with a trap over 90. I lost to a viper who is a exceptional driver he ran a 7.7 and beat a 03 Cobra (pulleys and drag radials) cause he red lighted bad. Neither the cobra or viper pulled me by much maybe a half car. My MPH was 3 mph slower than the cobra and 1.6 mph slower than the viper. They both dynoed over 420 so I was giving up at least 80 rwhp and more torque. I gave up .07 seconds from 330-620 to the viper and I was gaining ground .05 seconds on the cobra.
I still cant get better than a 1.85 60' on drag radials but it is consistant. For those with autos, do a burn out in second it works much better.
Fun night I wish Gary was there he would have beat both of them on time alone!
I will be getting some electric cutouts as soon as I find someone to install them, I need another .1 secs to have a chance at a 11 in the 1/4.
Feel free to comment or any sugguestions for a better 60' would be appreciated. i tried 3500 rpm power braking worked the best 1.85 60 and over 90 mph.
Old 09-14-2003, 03:25 AM
kumar75150
kumar75150's Avatar
Default Re: Denton 1/8th mile times and a few performance thoughts! (cscollis)
Scott, what size drag radials are you using?
Old 09-14-2003, 06:02 AM
WALLstAL
WALLstAL's Avatar
St. Jude Donor '05
Default Re: Denton 1/8th mile times and a few performance thoughts! (kumar75150)
A little larger cam would have done wonders! :yesnod: :yesnod:
Old 09-14-2003, 06:10 AM
MY1Fast99C5
MY1Fast99C5's Avatar
Default Re: Denton 1/8th mile times and a few performance thoughts! (wallstAL)
I have a small one and am getting decent times. :yesnod:
Old 09-14-2003, 10:06 AM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
Those are great times considering your mods :cheers:
I also think you can probably take atleast another 1/10 off your 60' time using the drag radials which will greatly affect your 1/8 mile time
Old 09-14-2003, 02:58 PM
cscollis
cscollis's Avatar
275 35 18 were the only available when I needed them. I would have gone 295 35 18 but they were on back order.
My biggest problem is my converter does not hit hard enough for 1.7 sixties. I tried 1 time last night to launch from idle so the cenverter would hit harder but it spun and hopped. I still ran a 7.99 with a 2.0 60 on that run!
[Modified by cscollis, 2:00 PM 9/14/2003]
Old 09-14-2003, 03:08 PM
MC TORCH RED
MC TORCH RED's Avatar
scott sell that t/c on the forum and get you a st3500 or a ss3800 and you will give gary a good azz spanking, you may have to get a little more stick in that vert also....good luck see you in hallsville. :yesnod:
Old 09-14-2003, 06:05 PM
cscollis
cscollis's Avatar
Default Re: Denton 1/8th mile times and a few performance thoughts! (MC TORCH RED)
I think I will be selling my Yank 3000 and buy Gary's SS3600. I think Gary is getting a bigger stall. I actually have a better mph and with a couple more fine computer adjustments (Chris Roberson is going to setup my shift points higher. 6400 intstead of 6150, I should get 7.8 with a 1.85 60'.
With a better stall I could get 7.6.
Old 09-14-2003, 09:11 PM
2001 Red Coupe Bandit
2001 Red Coupe Bandit's Avatar
Scott Congrats on the New Best Time.
I just got back in town tonight. I think your out of town for the next week so we will have talk later. I am gone the 18-21st and the 24-25th.
Congrats :cheers:
Gary
Old 09-15-2003, 01:18 AM
LittleBoyBlu99
LittleBoyBlu99's Avatar
Default Re: Denton 1/8th mile times and a few performance thoughts! (2001 Red Coupe Bandit)
Scott that Yank 3000 can get you in the 1.70 60fts. Try 19psi in the tires and besure to get those shift points raised to 6400. Then try launching at 16-1800rpm.go around the water box with the front tires so they want trail water up to the line.I cut 1.7s with my PT2800 and a best of a 1.68. :thumbs: Come early to Hallsville and get a little practice, see ya there. :seeya
Old 09-15-2003, 08:43 AM
cscollis
cscollis's Avatar
Default Re: Denton 1/8th mile times and a few performance thoughts! (LittleBoyBlu99)
i will be there, I always go around the waterbox and back in to heat the rears. My problem is I dont spin at all off the line. I will tried that 1600 and it hooked but still only a 1.88. I will try again in hallsville!
Old 09-15-2003, 11:06 AM
LittleBoyBlu99
Don't forget to raise those shift points to 6400 it could make a difference in 60ft & ET.
:thumbs: :cheers: :party:
To Denton 1/8th mile times and a few performance thoughts!
Quick Reply: Denton 1/8th mile times and a few performance thoughts!
