valve spring removal tool
Old 08-14-2003, 03:24 PM
pdd000
pdd000's Avatar
Default valve spring removal tool
any1 know where to get one at a good price
Old 08-14-2003, 03:25 PM
jmX
jmX's Avatar
Default Re: valve spring removal tool (pdd000)
Autozone or napa, $12.
Old 08-14-2003, 05:42 PM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
Tbryne sells a tool also, heres the link :cheers:
http://www.tbyrnemotorsports.com/c5catalog.html
Old 08-14-2003, 05:45 PM
0Vette Stripes
Former Vendor
Vette Stripes's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08
I bought 1 at Autozone and it is easy to remove springs but hard to install.
I ended up borrow the spring removal tool at the same Autozone :D to install my double Rev springs.
So my answer to borrow at a local Autozone :D
Old 08-14-2003, 06:05 PM
gojo
gojo's Avatar
http://www.moreperformanceinc.com/
Old 08-14-2003, 08:20 PM
C5-VERT
Support Corvetteforum!
C5-VERT's Avatar
Cruise-In IV Veteran
Default Re: valve spring removal tool (jfpilla)
:withstupid: No question that is the tool to get. The innermost valves are a pita to get to with a standard valve spring tool.
I just bought the moore valve tool yesterday from ThunderRacing.com.
Old 08-14-2003, 08:36 PM
0Vette Stripes
Former Vendor
Wow, that tool looks awsum ... I may get it when my spring is broken :D
Old 08-14-2003, 08:45 PM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
are you planning on using the type that you have to charge the cylinders with compressed air?
vetterdstr :cheers:
Old 08-14-2003, 08:54 PM
Patches
Patches's Avatar
Default Re: valve spring removal tool (C5-VERT)
Has anybody here actually used this tool successfully on at least one full set of springs? I know a guy who bought one and told me it fell apart by the time he finished his first set of springs. He went and bought 2 of the cheap $15 AutoZone tools to do the next set. One of them he cut down to do the springs in the back.
Old 08-14-2003, 08:56 PM
C5-VERT
C5-VERT's Avatar
Default Re: valve spring removal tool (Patches)
I am pretty sure Tom Garland liked it. He was who recommended me to get one.
Old 08-14-2003, 09:03 PM
Patches
Patches's Avatar
Well, if Tom rec's it, must be good. I was looking to make my own similar to that one. It appears they used a lower grade AL so I was thinking of using a 6061-T6. Basically, it's a rocker arm with a square hole for the ratchet. :yesnod:
Old 08-14-2003, 10:51 PM
rwj383
rwj383's Avatar
I have the More Performance spring tool for sale if you want it (slightly used but great shape). It's yours for $120 shipped. Email me at rjudd@tqs.com
Robert Judd
Old 08-14-2003, 11:52 PM
pdd000
pdd000's Avatar
Default Re: valve spring removal tool (vetterdstr)
vetterdstr :cheers:
im useing the Comp Cams 26918 Valve Springs
Old 08-14-2003, 11:56 PM
pdd000
pdd000's Avatar
Default Re: valve spring removal tool (jmX)
how do these work compare to a 120dollar moore tool
Old 08-15-2003, 07:02 AM
big bollas
big bollas's Avatar
I have done 3 sets and the "More" tool is the way to go :thumbs: I did not like the price but after I used it I knew it saved me alot of time in swaping the springs out. I tryed the one from auto zone but it was a pain in the azz to work with when doing the rear springs. :mad then went ahead and bought the "More" tool and wala :hurray:
Old 08-15-2003, 09:29 AM
tbyrne
tbyrne's Avatar
Location: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default Re: valve spring removal tool (runamuk)
TByrne sells a tool also, heres the link http://www.tbyrnemotorsports.com/c5catalog.html
We also carry the More Performance tool -
Info listed for this is -
"In car" valve spring changes have never been easier for the home hot rodder . Works on C5, F Bodies and all LS1 powered vehicles. The main body is made of billet aluminum and incorporates a steel roller bearing trunion for ease of operation. This tool is designed to work with any 3/8 hand ratchet, simply add a 3/8 extension for valve springs which are difficult to reach (under cowl). Will work on factory conical valve spring along with aftermarket 1.25" OD spring/retainer sets. For anyone changing camshafts with more than .500 valve lift , this tool is a must! Patent Pending. - $129.99
Very nice piece!
Tom
[Modified by tbyrne, 9:30 AM 8/15/2003]
To valve spring removal tool
Quick Reply: valve spring removal tool
