brake ?
Old 08-04-2003, 10:20 AM
lowprofiling
lowprofiling's Avatar
Default brake ?
i posted this in general by mistake
any problem fitting a set of OEM front rotors, and calipers on the rear? The stocks look to small. I know some are going to chime in and say get the Eradispeeds, but for me cruising around the local streets I really can find better things to spend $600-$800 on. I was thinking factory set up on the back and powder coat the calipers and can have a nice look at a good price. thanks
Old 08-04-2003, 11:03 AM
carpe dm
carpe dm's Avatar
Default Re: brake ? (lowprofiling)
Save your money; GM spent a lot of it engineering the brake system. Perhaps if you coated/painted them they would not look "to" small. :rolleyes:
Old 08-04-2003, 11:18 AM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
I agree that the brakes look small. You can install the front brake system on the rear, many have already done it. There are some down sides to it though...
vetterdstr :cheers:
Old 08-04-2003, 11:30 AM
lowprofiling
Default Re: brake ? (vetterdstr)
vetterdstr-
a few downsides? such as ????
Old 08-04-2003, 11:38 AM
vetterdstr
vetterdstr's Avatar
Loosing your parking brake, having the brake bias off because of the diff calipers and larger rotor. If you want to get serious about switching your brakes, buy a proven kit that wont give you any of the downsides that I talked about.
vetterdstr :cheers:
Old 08-04-2003, 11:45 AM
lowprofiling
i was thinking the car may brake diiferent because of the larger rotor. thanks for the info. maybe best to leave alone, or just change the caliper. :cheers:
Old 08-04-2003, 12:05 PM
vetterdstr
vetterdstr's Avatar
:cool: :cheers:
vetterdstr :chevy
To brake ?
Quick Reply: brake ?
