Should I install z06 screens?
Old 07-30-2003, 02:19 PM
Heretic
Heretic's Avatar
Default Should I install z06 screens?
Do they help? I just installed a Blackwing.
Old 07-30-2003, 02:31 PM
bandit_99
bandit_99's Avatar
Default Re: Should I install z06 screens? (Heretic)
Sure- If you like how they look. They will probably not be functional until you remove or cut some holes in your fog light shrouds.
They will allow for colder air to enter the engine compartment, but how much it helps is suspect. An intake like the Varam has had great reports, but that's designed to collect the air right into the intake.
You might consider doing a search for Z06 screens. Last week I found some threads that posted the same screen material as used by GM. You can make your own with $20 worth of screen + $5 in Velcro and + $2 for screen spleen.
Old 07-30-2003, 03:43 PM
allanlaw
allanlaw's Avatar
I assume you intend to install them after you remove the shrouds. The air passing though the screens will reduce your intake air temp - I measured this result with autotap when I opened up my shroud area. Lower intake air temp has a positive effect on power - not huge, but every little bit counts :) That's why they put the screens on the Z.
Old 07-30-2003, 04:25 PM
krabtree13
krabtree13's Avatar
Default Re: Should I install z06 screens? (allanlaw)
you definitely need to drill holes in the fog light shrouds(i drilled 13 1/2 in. holes in each side to allow the air to flow into the blackwing.supposedly a 10-15 h.p. increase,plus a wee bit of a throatier sound.best mod that i've done so far! :steering:
Old 07-30-2003, 04:57 PM
aaaa
aaaa's Avatar
Default Re: Should I install z06 screens? (krabtree13)
I didn't drill holes I cut out the entire center leaving only a little around the edges. I don't have any numbers be it just makes sense that it would help-plus it looks cool!
Old 07-30-2003, 05:00 PM
rbartick
rbartick's Avatar
Location: Admit Nothing, Deny Everything, Make Counter Accusations.
If you install the screens you should remove the factory plastic air deflectors & leave them off. This is certainly a worthwhile mod.
Old 07-30-2003, 05:51 PM
vette-lee
vette-lee's Avatar
Default Re: Should I install z06 screens? (rbartick)
those of u who drilled holes or cut a section, did u take the shroud out to do it or done it while in place? if u took it out, was that difficult?
thanks.
Old 07-30-2003, 06:44 PM
aaaa
aaaa's Avatar
Default Re: Should I install z06 screens? (vette-lee)
I did it in place. If your going to go to the trouble of taking them out-leave them out-no need for holes.
Old 07-30-2003, 09:47 PM
curtowens
curtowens's Avatar
Default Re: Should I install z06 screens? (aaaa)
I wanted a professional look so I actually installed the open air shroud kit with the screens sold by Mid America. It looks nice and has to improve power due to so much more cold air getting to the intake.
[Modified by curtowens, 9:48 PM 7/30/2003]
To Should I install z06 screens?
Quick Reply: Should I install z06 screens?
