LS1 Edit/Dyno Tune With Only Simple Mods. Worth It?
Old 07-15-2003, 02:12 PM
123Gone
123Gone's Avatar
Default LS1 Edit/Dyno Tune With Only Simple Mods. Worth It?
Mods are Blackwing, Stingers, Hurst on a MN6. Is it worth the $$$ to get a LS1 Edit dyno tune?
Old 07-15-2003, 02:16 PM
mdhmi
mdhmi's Avatar
Default Re: LS1 Edit/Dyno Tune With Only Simple Mods. Worth It? (123Gone)
Depends how much $ you can get it done locally for. I spoke w/ two local performance shops last week about the LS1 Edit. Both shops charge around $500.00 for the Edit. Both shops reported that I would likely only see a 5 rwhp improvement on my 2000 M6 with Donaldson Blackwing and LS6 intake. So in short the answer is no.
Mark
Old 07-15-2003, 02:21 PM
boost2much
boost2much's Avatar
Default Re: LS1 Edit/Dyno Tune With Only Simple Mods. Worth It? (mdhmi@yahoo.com)
You could always go the MAFT route. You can find them used for aournd $100-75. That's what I did untill I get the cam and heads installed. Then I will use LS1 edit. I was running lean with the mods below. WIth the MAFT, I richened it up and I could feel a SOTP difference.
Old 07-15-2003, 02:32 PM
dmcantrell
dmcantrell's Avatar
Default Re: LS1 Edit/Dyno Tune With Only Simple Mods. Worth It? (boost2much)
What is MAFT??
I had a Halltech TRAP installed, which freaked out the computer and the car was detonating (obvious from the dyno graphs -- pulling timing by like 8-12 degrees). After LS1 Edit, I got no detonation, and another 13 RWHP. I think it's worth it -- not so much for the gain, but to tune the car to run correctly based on what you've done to it.
--dc.
To LS1 Edit/Dyno Tune With Only Simple Mods. Worth It?
Quick Reply: LS1 Edit/Dyno Tune With Only Simple Mods. Worth It?
