Changing my M6 tranny fluid?
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Re: Changing my M6 tranny fluid? (Yano)
YANO
What type AMSOIL fluid did you yse in your trans? They have a few types of ATF.. Which one is the one to use?
Bill C
Bill C
Re: Changing my M6 tranny fluid? (SLICKMAN)
Thanks for the info changing the M6 tranny fluid is my next maintenance item since I am at 30,000 miles. Mobil 1 syn ATF is probably going to be my choice.
When you have a hard time getting it into first, does it sometimes grind a little because it was not all the way engaged and you thought it was?.
I'm used to it but it's one of the reasons why i don't valet my car.
I don't have any issues at all with any other gear. I'm hoping changing the fluid will help this! It's horrible when the light turns green and i'm trying to find first gear :mad
Re: Changing my M6 tranny fluid? (Bill Curlee)
YANO
Bill C
Bill C
Amsoil only makes one type of ATF. If you interested in a price email me :)
Perry
nastyrt10@aol.com
Re: Changing my M6 tranny fluid? (NYtoCA)
Yep, thats what mine does, now I know I'm not alone..
It will only grind if i lift on the clutch alittle bit....otherwise i have to put it into other gears (3rd seems to work) before going into first gear.
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Mine was doing the grinding thing. The synthetic seems to have cured it.
Re: Changing my M6 tranny fluid? (Eric Fischer)
How long have you guys been running syncromesh? I really want to go this route since this is the GOD of all oils in my Talon (it wont shift without it.) I'm just hesitant to use it in my vette.
Re: Changing my M6 tranny fluid? (HurricaneZ)
I have been running Synchromesh for about 3 mos now.. I love it.. The weird part is it seem to have gotten even better in the past month. :smash: :smash:
That's exactly what mine does! It seems as though it takes "two clicks" to get the tranny into first. I have retrained myself to place extra force on the shifter anytime I put it into first. Now I find myself doing the same thing in my daily driver Mustang too. :lol:
I believe it has two synchros per gear. What you are feeling is the second synchro engaging.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Re: Changing my M6 tranny fluid? (IMQUIK)
IMQUIK
Which amsoil automatic tranny fluid did you use? They sell a couple of different types from normal duty to full race.
Bill Curlee
Bill Curlee
#33
Re: Changing my M6 tranny fluid? (Mark 84ltblu)
Thanks for the info! My 2000 also sometimes has a problem with first ( strange the dealer could never find it!) I'm going to change the trans fluid ASAP!
#35
IMQUIK
Bill Curlee
Bill Curlee
