Z06 front screen
Old 07-10-2003, 04:34 PM
02MillenniumVette
02MillenniumVette's Avatar
Default Z06 front screen
Do I need to install the cold air screens, pictured below, before I can install the Z06 front screen? Thanks in advance.
Old 07-10-2003, 04:47 PM
gmf
gmf's Avatar
Default Re: Z06 front screen (02MillenniumVette)
I'd do the cold air screens first, just to give you more arm room. You need to come up underneath your car to put in the cold air screens.
Old 07-10-2003, 05:04 PM
dmcantrell
dmcantrell's Avatar
Default Re: Z06 front screen (gmf)
I don't believe you even need the Z06 screens (after the fog-light shrouds you have pictured are installed), unless you like the look.
But to answer your question, NO -- they do not **need** to be installed first. However, not having the Z06 screens there will give you more arm room (as mentioned above) when doing to the fog light shrouds.
--dc.
[Modified by dmcantrell, 4:05 PM 7/10/2003]
Old 07-10-2003, 05:36 PM
Patches
Support Corvetteforum!
Patches's Avatar
I just pulled out my fog light shrouds and put in the Z06 screens without putting in cold air screens.
Here's what the stock fog light shroud looks like.
Old 07-10-2003, 06:44 PM
aaaa
aaaa's Avatar
Default Re: Z06 front screen (Patches)
They are entended to be used separately. One or the other. :yesnod:
Old 07-10-2003, 07:14 PM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
:iagree:
I did the same thing, I could feel the car was running better just from doing this :yesnod:
To Z06 front screen
Quick Reply: Z06 front screen
