valve spring wars, where are we at?
having just broke a CC918 spring begs the age-old question: what are the most reliable high-perf springs available for LS1?? I try to keep my finger on the pulse of this topic but have not drawn a definitive conclusion. As Shirl builds my 436cid LS1 solid roller, springs will be a big issue. I am aware of the many dual spring setups that are proving to be reliable, but then i hear of the horror stories of the rocker bosses pulling out of the head due to the weaknesses created from the required machine work for the spring (and heavy intake ceiling porting). for cams with <.625 lift i am now hearing the Manley single ovate spring, #221423, is proving to be more reliable than the CC918. anyone can vouch for this?? Would like to hear some input on the latest experiences.
Robert Judd
GenIII Motorsports
Robert Judd
GenIII Motorsports
Re: valve spring wars, where are we at? (rwj383)
I would recommend the rev 1116. It fits the stock spring pocket, and doesn't require you to cut the head, unlike the comp 1.75" double spring.
54-VS1116 REV Dual Valve Springs, 1.25" OD (For stock spring pocket) Must use with 54-SC221 Hardened Seats & 54-TR9814 Titanium Retainers $139.99
54-SC221 REV Hardened Spring Seats for 54-VS1116 1.25" Double Valve Springs $44.99
54-TR9814 REV Titanium Retainers for 54-VS1116 1.25" Double Valve Springs $149.99
Re: valve spring wars, where are we at? (J-Rod)
I also have the Rev 1116s on my car, no touble so far. I understand that Comp is also coming out with a dual spring that does not require machining your heads.
[Modified by Mitch C, 2:18 PM 6/12/2003]
Re: valve spring wars, where are we at? (Mitch C)
My heads from Katech came with the Comp Cams 941 spring, and afte 15k miles I have now broke 2 springs in the last 2k miles. Comp Cams told me to get the 918 spring, but I see that yours broke. My cam lift is 579, will the 918 work for me?
Thanks,
Shawn
Thanks,
Shawn
Re: valve spring wars, where are we at? (Shawn84&92)
Thanks,
Shawn
Thanks,
Shawn
Robert
RWJ, I have not seen a single Rev 1119 spring failure here on the forum! Please enlighten me!
This subject is near and dear to my heart because I didn't get a big cam and more HP because of FEAR of spring failure.
I want to see the failure posts!
Hey rwj383, I run an ARE solid setup with 640 lift. I have 977 cc springs with T&D shaft rockers, never a problem. My cam is 640/640, 236/236, 112 lsa. Wish I had your cubes, though! :crazy: :cheers:
Re: valve spring wars, where are we at? (ScreaminDemon)
<BLOCKQUOTE>code:<HR><PRE> Seat Open
Mfg P/N Outer Outer Inner Rate Seat Open rate @ rate @ Lift
OD ID ID 1.75 1.11 Coil Bind b4 coil bind 1.78 1.165
Crane 99893- 1.46 1.075 0.803 408 165 426 1.08 .085 152 414 I 0.615
99893C- 152 414 E 0.615
Seat Open
OD ID ID 1.75 1.11 Coil Bind b4 coil bind 1.75 1.135
Comp 987 1.46 1.075 0.803 378 138 380 1.1 .035 138 372 I 0.615
138 372 E 0.615
</PRE>[/QUOTE]
Seat Open
138 372 E 0.615
</PRE>[/QUOTE]
I have the ISKY Gold single springs. I think the model number is 295D. My tuner tells me they are guaranteed to .630 lift and he will comfortably put up to .650 lift on them.
His car has a big ole cam + rockers ammounting to about .670 lift and the ISKYs have not given yet. :cheers:
Re: valve spring wars, where are we at? ('97 C5)
'97 C5,
Thank you for posting numbers. First time I've seen spring numbers on any of these forums. They tell so much more than the typical "ACME #1234 springs are good for .580 lift" and "I have the BOUNCER 695's and my motor runs fine". None of these subjective statements means anything other than that spring works in that particular combination of cam grind, valve and retainer weight, RPMs, pushrods, etc. Most of the time, these other related particulars are NOT listed. This kind of data should be archived Cam numbers too. I don't mean just lift, duration and LSA but any Cam Dr. or EZ-Cam info (velocity, accel, etc.).
Based on the data you posted, I'm gonna look at the Comp 987 for a motor with .588 net lift, slightly higher than stock velocity and accel, 6800 RPM chip. Putting this spring in at 1.720 installed ht. will give about 150# seat and 388# open @ .032" (plus deflection) from coilbind. This provided the 987 doesn't have a bad rep for breakage (anyone?). I think this spring looks good for less than .600 lift if set up tight. It's a little wimpy on seat pressure over .600 lift. The Crane you listed would certainly control this valvetrain but would put more load on the cam, lifter and pushrod. I wouldn't think of running this spring with any less than a 3/8 pushrod. In fact I'll use 3/8 x .080 with the Comp spring.
Enough rambling.... Anyone else got numbers, spring or cam... post 'em and ask the moderators to archive this stuff.
Platinum Supporting Vendor
Re: valve spring wars, where are we at? (Walt Donovan)
We now have REV 1116 springs that are chrome plated. Somehow this is supposed to make them stronger.
Re: valve spring wars, where are we at? (CJS)
Andy at A&A may be able to cite specific examples of failures of these springs. What i have found on the other posts like LS1Tech.com and LS1.com also concerned me. go to these sites and do a search..
