My baby on a flatbed this AM
My baby on a flatbed this AM/Broken Valve Springs
:confused:
Not sure what the problem is... I was on my way home from a race on Sunday and my car started to sound very strange. I only race a couple of times a year and my car ran really well, to hot to set a personal best but she ran well.
Sort of a muffled sound, which was accompanied by a decrease in power. No lights, no codes. She does not want to idle well at all.
I have about 70K on her and she is maintained very, very well. I am hoping for something simple like bad gas or plugged fuel filter or plugged cats.
Any other ideas?
She sure look sad on the truck with her new personalized plates "DARNFST"
4 Broken valve springs... :(
[Modified by Cha Cha, 7:21 PM 6/9/2003]
Any other ideas?
Re: My baby on a flatbed this AM (Cha Cha)
did you check your mafs intake. If you are getting unregulated air, it will cause a large decrease in power and result in a lower exhaust note.
Spray some starter fluid around the intake and anywhere where two pieces of plastic meet. If the car revs, then you have a leak.
Re: My baby on a flatbed this AM (ICULUKN-C5)
I had just oiled the filter so, I thought that I may have excess oil on the wires of the MAF. I removed from the Throttle body back cleaned and replaced. It did not make a difference.
BS? Are you so wrapped up in your car that you call BS on anyone with a problem. What picture do you need? the car on the flat bed.
Cha Cha, haven't seen you post on the forum for a while :cheers:
Hope you get it fixed quickly. Check all of the connections for leaks if you took the filter off. Also check that nothing got sucked up into the ProFlow+. I ran over a plastic bag on the highway once and it acted the same way. The plastic had wrapped itself around most of the K & N filter.
[Modified by MMarquez, 9:58 PM 6/3/2003]
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Re: My baby on a flatbed this AM (MMarquez)
Sounds like it could be a valvespring as well. I see you have a heads and cam package done. Do you know what valvesprings were used in your heads? There were many bad batches of valvesprings from a few different companies over the last couple years. Also, valvesprings are a maintenance item when you run an aftermarket camshaft. I would say at least once every two years depending on how much you drive it.
[Modified by MattG, 12:27 AM 6/4/2003]
Cruise-In IV Veteran
Cruise-In V Veteran
Re: My baby on a flatbed this AM (Michael Joslyn)
[Modified by Tormania, 10:02 AM 6/4/2003]
Former Vendor
Re: My baby on a flatbed this AM (Tormania)
It's an Off Topic inside joke. No harm, no foul! :cheers:
Re: My baby on a flatbed this AM (CP)
No problem. It has been a while since I have been around... I will let you folks know when they find the problem...
Think inexpensive.. :)
Re: My baby on a flatbed this AM (MattG)
:iagree:
CI 3-4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Re: My baby on a flatbed this AM/Broken Valve Springs (Cha Cha)
4 Broken Valve Springs..... :(
Re: My baby on a flatbed this AM/Broken Valve Springs (98Pace97Coupe)
Did you happen to catch what type of valvesprings they were? My guess is Comp Cams 941s..
Re: My baby on a flatbed this AM/Broken Valve Springs (MattG)
Not sure what valve springs but, I will find out.. Do you have a better replacement suggestion?
Thankx for the Hug.. :)
